ACPI: EC: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
- to = \(kmalloc\|kzalloc\)(size,flag);
+ to = kmemdup(from,size,flag);
if (to==NULL || ...) S
- memcpy(to, from, size);
Signed-off-by: Julia Lawall
Acked-by: Alexey Starikovskiy
Signed-off-by: Len Brown
drivers/acpi/ec.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/acpi/ec.c b/drivers/acpi/ec.c
index f2234db..e61d4f8 100644
--- a/drivers/acpi/ec.c
+++ b/drivers/acpi/ec.c
@@ -1027,10 +1027,9 @@ int __init acpi_ec_ecdt_probe(void)
/* Don't trust ECDT, which comes from ASUSTek */
if (!EC_FLAGS_VALIDATE_ECDT)
goto install;
- saved_ec = kmalloc(sizeof(struct acpi_ec), GFP_KERNEL);
+ saved_ec = kmemdup(boot_ec, sizeof(struct acpi_ec), GFP_KERNEL);
if (!saved_ec)
return -ENOMEM;
- memcpy(saved_ec, boot_ec, sizeof(struct acpi_ec));
/* fall through */
goto install;
if (!saved_ec)
return -ENOMEM;
/* fall through */
