drivers/net/wireless/wl1251: add missing kfree
In each case, the kfree already at the end of the function is also needed
in the error case.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...kfree(x)...+> }
when any
when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
when forall
return \(0\|<+...x...+>\|ptr\);
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
drivers/net/wireless/wl1251/acx.c | 6 +-----
drivers/net/wireless/wl1251/cmd.c | 2 +-
2 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/net/wireless/wl1251/acx.c b/drivers/net/wireless/wl1251/acx.c
index ef8370e..ad87a1a 100644
--- a/drivers/net/wireless/wl1251/acx.c
+++ b/drivers/net/wireless/wl1251/acx.c
@@ -140,8 +140,6 @@ int wl1251_acx_sleep_auth(struct wl1251 *wl, u8 sleep_auth)
auth->sleep_auth = sleep_auth;
ret = wl1251_cmd_configure(wl, ACX_SLEEP_AUTH, auth, sizeof(*auth));
- if (ret < 0)
- return ret;
out:
kfree(auth);
@@ -681,10 +679,8 @@ int wl1251_acx_cca_threshold(struct wl1251 *wl)
ret = wl1251_cmd_configure(wl, ACX_CCA_THRESHOLD,
detection, sizeof(*detection));
- if (ret < 0) {
+ if (ret < 0)
wl1251_warning("failed to set cca threshold: %d", ret);
- return ret;
out:
kfree(detection);
diff --git a/drivers/net/wireless/wl1251/cmd.c b/drivers/net/wireless/wl1251/cmd.c
index 81f164b..d14d69d 100644
--- a/drivers/net/wireless/wl1251/cmd.c
+++ b/drivers/net/wireless/wl1251/cmd.c
@@ -241,7 +241,7 @@ int wl1251_cmd_data_path(struct wl1251 *wl, u8 channel, bool enable)
if (ret < 0) {
wl1251_error("tx %s cmd for channel %d failed",
enable ? "start" : "stop", channel);
- return ret;
+ goto out;
wl1251_debug(DEBUG_BOOT, "tx %s cmd channel %d", |
- if (ret < 0)
- return ret;
out:
kfree(auth);
- if (ret < 0) {
+ if (ret < 0)
- return ret;
out:
kfree(detection);
if (ret < 0) {
- return ret;
+ goto out;
