arch/powerpc/sysdev/ehv_pic.c: add missing kfree
At this point, ehv_pic has been allocated but not stored anywhere, so it
should be freed before leaving the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...kfree(x)...+> }
when any
when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
when forall
return \(0\|<+...x...+>\|ptr\);
* return ...;
Signed-off-by: Julia Lawall
Acked-by: Timur Tabi
Signed-off-by: Kumar Gala
arch/powerpc/sysdev/ehv_pic.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/arch/powerpc/sysdev/ehv_pic.c b/arch/powerpc/sysdev/ehv_pic.c
index af1a5df..b6731e4 100644
--- a/arch/powerpc/sysdev/ehv_pic.c
+++ b/arch/powerpc/sysdev/ehv_pic.c
@@ -280,6 +280,7 @@ void __init ehv_pic_init(void)
if (!ehv_pic->irqhost) {
of_node_put(np);
+ kfree(ehv_pic);
return;
of_node_put(np);
+ kfree(ehv_pic);
return;
