drivers/net/wireless/p54/eeprom.c: Return -ENOMEM on memory allocation failure
In this code, 0 is returned on memory allocation failure, even though other
failures return -ENOMEM or other similar values.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression ret;
expression x,e1,e2,e3;
ret = 0
... when != ret = e1
*x = \(kmalloc\|kcalloc\|kzalloc\)(...)
... when != ret = e2
if (x == NULL) { ... when != ret = e3
  return ret;
Signed-off-by: Julia Lawall
Cc:
Acked-by: Christian Lamparter
Signed-off-by: John W. Linville
 drivers/net/wireless/p54/eeprom.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/wireless/p54/eeprom.c b/drivers/net/wireless/p54/eeprom.c
index 8c05266..35b09aa 100644
--- a/drivers/net/wireless/p54/eeprom.c
+++ b/drivers/net/wireless/p54/eeprom.c
@@ -261,8 +261,10 @@ static int p54_generate_channel_lists(struct ieee80211_hw *dev)
 	list->max_entries = max_channel_num;
 	list->channels = kzalloc(sizeof(struct p54_channel_entry) *
 				 max_channel_num, GFP_KERNEL);
-	if (!list->channels)
+	if (!list->channels) {
+		ret = -ENOMEM;
 		goto free;
 	for (i = 0; i < max_channel_num; i++) {
 		if (i < priv->iq_autocal_len) {
BtrLinux
Privacy Overview
