SERIAL: ioc3_serial: Return -ENOMEM on memory allocation failure
In this code, 0 is returned on memory allocation failure, even though other
failures return -ENOMEM or other similar values.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression ret;
expression x,e1,e2,e3;
ret = 0
... when != ret = e1
*x = \(kmalloc\|kcalloc\|kzalloc\)(...)
... when != ret = e2
if (x == NULL) { ... when != ret = e3
return ret;
Signed-off-by: Julia Lawall
To: Pat Gefre
Cc: kernel-janitors@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/1704/
Signed-off-by: Ralf Baechle
drivers/serial/ioc3_serial.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/serial/ioc3_serial.c b/drivers/serial/ioc3_serial.c
index 93de907..800c546 100644
--- a/drivers/serial/ioc3_serial.c
+++ b/drivers/serial/ioc3_serial.c
@@ -2044,6 +2044,7 @@ ioc3uart_probe(struct ioc3_submodule *is, struct ioc3_driver_data *idd)
if (!port) {
printk(KERN_WARNING
"IOC3 serial memory not available for port\n");
+ ret = -ENOMEM;
goto out4;
spin_lock_init(&port->ip_lock); |
if (!port) {
printk(KERN_WARNING
+ ret = -ENOMEM;
goto out4;
