drivers/net/wan/dscc4.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Move up the initialization of rc so that failure of pci_alloc_consistent
returns -ENOMEM as well.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e1,e2;
if (ret < 0)
 { ... return ret; }
 ... when != ret = e1
     when forall
*if(...)
  ... when != ret = e2
* return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/wan/dscc4.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/net/wan/dscc4.c b/drivers/net/wan/dscc4.c
index 9eb6479..ef36caf 100644
--- a/drivers/net/wan/dscc4.c
+++ b/drivers/net/wan/dscc4.c
@@ -774,14 +774,15 @@ static int __devinit dscc4_init_one(struct pci_dev *pdev,
 	/* Global interrupt queue */
 	writel((u32)(((IRQ_RING_SIZE >> 5) - 1) << 20), ioaddr + IQLENR1);
+	rc = -ENOMEM;
 	priv->iqcfg = (__le32 *) pci_alloc_consistent(pdev,
 		IRQ_RING_SIZE*sizeof(__le32), &priv->iqcfg_dma);
 	if (!priv->iqcfg)
 		goto err_free_irq_5;
 	writel(priv->iqcfg_dma, ioaddr + IQCFG);
-	rc = -ENOMEM;
 	 * SCC 0-3 private rx/tx irq structures
 	 * IQRX/TXi needs to be set soon. Learned it the hard way...
BtrLinux
Privacy Overview
