drivers/net/wimax/i2400m/fw.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e1,e2;
if (ret < 0)
 { ... return ret; }
 ... when != ret = e1
     when forall
*if(...)
  ... when != ret = e2
* return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/wimax/i2400m/fw.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/wimax/i2400m/fw.c b/drivers/net/wimax/i2400m/fw.c
index 283237f..def12b3 100644
--- a/drivers/net/wimax/i2400m/fw.c
+++ b/drivers/net/wimax/i2400m/fw.c
@@ -326,8 +326,10 @@ int i2400m_barker_db_init(const char *_options)
 		unsigned barker;
 		options_orig = kstrdup(_options, GFP_KERNEL);
-		if (options_orig == NULL)
+		if (options_orig == NULL) {
+			result = -ENOMEM;
 			goto error_parse;
 		options = options_orig;
 		while ((token = strsep(&options, ",")) != NULL) {
