drivers/net/via-velocity.c: remove exceptional & on function name
In this file, function names are otherwise used as pointers without &.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/via-velocity.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/via-velocity.c b/drivers/net/via-velocity.c
index 158f411..1e6b395 100644
--- a/drivers/net/via-velocity.c
+++ b/drivers/net/via-velocity.c
@@ -2176,7 +2176,7 @@ static int velocity_open(struct net_device *dev)
 	velocity_init_registers(vptr, VELOCITY_INIT_COLD);
-	ret = request_irq(vptr->pdev->irq, &velocity_intr, IRQF_SHARED,
+	ret = request_irq(vptr->pdev->irq, velocity_intr, IRQF_SHARED,
 			  dev->name, dev);
 	if (ret < 0) {
 		/* Power down the chip */
BtrLinux
Privacy Overview
