drivers/net/wan: remove exceptional & on function name
In this file, function names are otherwise used as pointers without &.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/wan/dscc4.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wan/dscc4.c b/drivers/net/wan/dscc4.c
index 81c8aec..63a0102 100644
--- a/drivers/net/wan/dscc4.c
+++ b/drivers/net/wan/dscc4.c
@@ -1127,7 +1127,7 @@ done:
init_timer(&dpriv->timer);
dpriv->timer.expires = jiffies + 10*HZ;
dpriv->timer.data = (unsigned long)dev;
- dpriv->timer.function = &dscc4_timer;
+ dpriv->timer.function = dscc4_timer;
add_timer(&dpriv->timer);
netif_carrier_on(dev); |
