drivers/net/qlcnic: Use available error codes
The error code is stored in the variable err, but it is the variable ret
that is returned instead.  So store the error code in ret.  Err is then
useless.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
local idexpression x;
constant C;
if (...) { ...
  x = -C
  ... when != x
  return <+...x...+>;
  return NULL;
  return;
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/qlcnic/qlcnic_main.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/qlcnic/qlcnic_main.c b/drivers/net/qlcnic/qlcnic_main.c
index abd7cd6..384cc52 100644
--- a/drivers/net/qlcnic/qlcnic_main.c
+++ b/drivers/net/qlcnic/qlcnic_main.c
@@ -474,7 +474,7 @@ static int
 qlcnic_init_pci_info(struct qlcnic_adapter *adapter)
 	struct qlcnic_pci_info *pci_info;
-	int i, ret = 0, err;
+	int i, ret = 0;
 	u8 pfn;
 	pci_info = kcalloc(QLCNIC_MAX_PCI_FUNC, sizeof(*pci_info), GFP_KERNEL);
@@ -484,14 +484,14 @@ qlcnic_init_pci_info(struct qlcnic_adapter *adapter)
 	adapter->npars = kzalloc(sizeof(struct qlcnic_npar_info) *
 				QLCNIC_MAX_PCI_FUNC, GFP_KERNEL);
 	if (!adapter->npars) {
-		err = -ENOMEM;
+		ret = -ENOMEM;
 		goto err_pci_info;
 	adapter->eswitch = kzalloc(sizeof(struct qlcnic_eswitch) *
 				QLCNIC_NIU_MAX_XG_PORTS, GFP_KERNEL);
 	if (!adapter->eswitch) {
-		err = -ENOMEM;
+		ret = -ENOMEM;
 		goto err_npars;
BtrLinux
Privacy Overview
