net/ax25: Use available error codes
Error codes are stored in err, but the return value is always 0. Return
err instead.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
local idexpression x;
constant C;
if (...) { ...
x = -C
... when != x
return <+...x...+>;
return NULL;
return;
* return ...;
Signed-off-by: Julia Lawall
Acked-by: Ralf Baechle
Signed-off-by: David S. Miller
net/ax25/af_ax25.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/ax25/af_ax25.c b/net/ax25/af_ax25.c
index cfdfd7e..26eaebf 100644
--- a/net/ax25/af_ax25.c
+++ b/net/ax25/af_ax25.c
@@ -1103,7 +1103,7 @@ done:
out:
release_sock(sk);
- return 0;
+ return err;
out:
release_sock(sk);
- return 0;
+ return err;
