drivers/net/ethernet/ti/davinci_cpdma.c: Remove potential NULL dereference
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If the NULL test is necessary, the initialization involving a dereference of
the tested value should be moved after the NULL test.
The sematic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/ti/davinci_cpdma.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/ti/davinci_cpdma.c b/drivers/net/ethernet/ti/davinci_cpdma.c
index 3b5c457..d15c888 100644
--- a/drivers/net/ethernet/ti/davinci_cpdma.c
+++ b/drivers/net/ethernet/ti/davinci_cpdma.c
@@ -538,11 +538,12 @@ EXPORT_SYMBOL_GPL(cpdma_chan_create);
 int cpdma_chan_destroy(struct cpdma_chan *chan)
-	struct cpdma_ctlr *ctlr = chan->ctlr;
+	struct cpdma_ctlr *ctlr;
 	unsigned long flags;
 	if (!chan)
 		return -EINVAL;
+	ctlr = chan->ctlr;
 	spin_lock_irqsave(&ctlr->lock, flags);
 	if (chan->state != CPDMA_STATE_IDLE)
BtrLinux
Privacy Overview
