drivers/net/ethernet/mellanox/mlx4/mcg.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
when != ret = e3
*if (x == NULL || ...)
... when != ret = e4
* return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ethernet/mellanox/mlx4/mcg.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/mellanox/mlx4/mcg.c b/drivers/net/ethernet/mellanox/mlx4/mcg.c
index 4ec3835..a018ea2 100644
--- a/drivers/net/ethernet/mellanox/mlx4/mcg.c
+++ b/drivers/net/ethernet/mellanox/mlx4/mcg.c
@@ -432,8 +432,10 @@ static int add_promisc_qp(struct mlx4_dev *dev, u8 port,
if ((be32_to_cpu(mgm->qp[i]) & MGM_QPN_MASK) == qpn) {
/* Entry already exists, add to duplicates */
dqp = kmalloc(sizeof *dqp, GFP_KERNEL);
- if (!dqp)
+ if (!dqp) {
+ err = -ENOMEM;
goto out_mailbox;
dqp->qpn = qpn;
list_add_tail(&dqp->list, &entry->duplicates);
found = true; |
- if (!dqp)
+ if (!dqp) {
+ err = -ENOMEM;
goto out_mailbox;
dqp->qpn = qpn;
found = true;
