drivers/net/ethernet/freescale/fs_enet: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
    when != ret = e3
*if (x == NULL || ...)
  ... when != ret = e4
*  return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/freescale/fs_enet/mii-bitbang.c | 4 +++-
 drivers/net/ethernet/freescale/fs_enet/mii-fec.c     | 8 ++++++--
 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/freescale/fs_enet/mii-bitbang.c b/drivers/net/ethernet/freescale/fs_enet/mii-bitbang.c
index 0f2d1a7..1514533 100644
--- a/drivers/net/ethernet/freescale/fs_enet/mii-bitbang.c
+++ b/drivers/net/ethernet/freescale/fs_enet/mii-bitbang.c
@@ -174,8 +174,10 @@ static int __devinit fs_enet_mdio_probe(struct platform_device *ofdev)
 	new_bus->phy_mask = ~0;
 	new_bus->irq = kmalloc(sizeof(int) * PHY_MAX_ADDR, GFP_KERNEL);
-	if (!new_bus->irq)
+	if (!new_bus->irq) {
+		ret = -ENOMEM;
 		goto out_unmap_regs;
 	new_bus->parent = &ofdev->dev;
 	dev_set_drvdata(&ofdev->dev, new_bus);
diff --git a/drivers/net/ethernet/freescale/fs_enet/mii-fec.c b/drivers/net/ethernet/freescale/fs_enet/mii-fec.c
index 55bb8672..cdf702a 100644
--- a/drivers/net/ethernet/freescale/fs_enet/mii-fec.c
+++ b/drivers/net/ethernet/freescale/fs_enet/mii-fec.c
@@ -137,8 +137,10 @@ static int __devinit fs_enet_mdio_probe(struct platform_device *ofdev)
 	snprintf(new_bus->id, MII_BUS_ID_SIZE, "%x", res.start);
 	fec->fecp = ioremap(res.start, resource_size(&res));
-	if (!fec->fecp)
+	if (!fec->fecp) {
+		ret = -ENOMEM;
 		goto out_fec;
 	if (get_bus_freq) {
 		clock = get_bus_freq(ofdev->dev.of_node);
@@ -172,8 +174,10 @@ static int __devinit fs_enet_mdio_probe(struct platform_device *ofdev)
+		ret = -ENOMEM;
BtrLinux
Privacy Overview
