drivers/net/bnx2x: Adjust confusing if indentation
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Acked-by: Eilon Greenstein
Signed-off-by: David S. Miller
 drivers/net/bnx2x/bnx2x_link.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/bnx2x/bnx2x_link.c b/drivers/net/bnx2x/bnx2x_link.c
index 0383e30..0fa0991 100644
--- a/drivers/net/bnx2x/bnx2x_link.c
+++ b/drivers/net/bnx2x/bnx2x_link.c
@@ -1254,11 +1254,11 @@ static void bnx2x_set_autoneg(struct link_params *params,
 		    PORT_HW_CFG_SPEED_CAPABILITY_D0_1G)
 			reg_val |= MDIO_CL73_IEEEB1_AN_ADV2_ADVR_1000M_KX;
-			CL45_WR_OVER_CL22(bp, params->port,
-					      params->phy_addr,
-					      MDIO_REG_BANK_CL73_IEEEB1,
-					      MDIO_CL73_IEEEB1_AN_ADV2,
-				      reg_val);
+		CL45_WR_OVER_CL22(bp, params->port,
+				      params->phy_addr,
+				      MDIO_REG_BANK_CL73_IEEEB1,
+				      MDIO_CL73_IEEEB1_AN_ADV2,
+			      reg_val);
 		/* CL73 Autoneg Enabled */
 		reg_val = MDIO_CL73_IEEEB0_CL73_AN_CONTROL_AN_EN;
BtrLinux
Privacy Overview
