drivers/net: Adjust confusing if indentation
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/gianfar.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/gianfar.c b/drivers/net/gianfar.c
index 4f7c3f3..3d9f958 100644
--- a/drivers/net/gianfar.c
+++ b/drivers/net/gianfar.c
@@ -1859,7 +1859,7 @@ static int register_grp_irqs(struct gfar_priv_grp *grp)
 				printk(KERN_ERR "%s: Can't get IRQ %d\n",
 					dev->name, grp->interruptError);
-				goto err_irq_fail;
+			goto err_irq_fail;
 		if ((err = request_irq(grp->interruptTransmit, gfar_transmit,
