drivers/isdn/gigaset/common.c: Remove useless kfree
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
when != e = e1
when != e += e1
when != e -= e1
when != ++e
when != --e
when != e++
when != e--
when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
Acked-by: Tilman Schmidt
Signed-off-by: David S. Miller
drivers/isdn/gigaset/common.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/drivers/isdn/gigaset/common.c b/drivers/isdn/gigaset/common.c
index aa41485..30a6b17 100644
--- a/drivers/isdn/gigaset/common.c
+++ b/drivers/isdn/gigaset/common.c
@@ -1123,7 +1123,6 @@ struct gigaset_driver *gigaset_initdriver(unsigned minor, unsigned minors,
return drv;
error:
- kfree(drv->cs);
kfree(drv);
return NULL;
return drv;
error:
- kfree(drv->cs);
kfree(drv);
return NULL;
