hwspinlock/core: move the dereference below the NULL test
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The dereference should be moved below the NULL test.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Ohad Ben-Cohen
drivers/hwspinlock/hwspinlock_core.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/hwspinlock/hwspinlock_core.c b/drivers/hwspinlock/hwspinlock_core.c
index 1201a15..db713c0 100644
--- a/drivers/hwspinlock/hwspinlock_core.c
+++ b/drivers/hwspinlock/hwspinlock_core.c
@@ -552,7 +552,7 @@ EXPORT_SYMBOL_GPL(hwspin_lock_request_specific);
int hwspin_lock_free(struct hwspinlock *hwlock)
- struct device *dev = hwlock->bank->dev;
+ struct device *dev;
struct hwspinlock *tmp;
int ret;
@@ -561,6 +561,7 @@ int hwspin_lock_free(struct hwspinlock *hwlock)
return -EINVAL;
+ dev = hwlock->bank->dev;
mutex_lock(&hwspinlock_tree_lock);
/* make sure the hwspinlock is used */ |
int ret;
return -EINVAL;
