drivers/isdn: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f = E
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/isdn/hardware/mISDN/hfcmulti.c | 2 ++
1 file changed, 2 insertions(+)
diff --git a/drivers/isdn/hardware/mISDN/hfcmulti.c b/drivers/isdn/hardware/mISDN/hfcmulti.c
index 595ba8e..0b28141 100644
--- a/drivers/isdn/hardware/mISDN/hfcmulti.c
+++ b/drivers/isdn/hardware/mISDN/hfcmulti.c
@@ -4599,6 +4599,7 @@ init_e1_port(struct hfc_multi *hc, struct hm_map *m)
printk(KERN_ERR "%s: no memory for coeffs\n",
__func__);
ret = -ENOMEM;
+ kfree(bch);
goto free_chan;
bch->nr = ch;
@@ -4767,6 +4768,7 @@ init_multi_port(struct hfc_multi *hc, int pt)
__func__);
ret = -ENOMEM;
+ kfree(bch);
goto free_chan;
bch->nr = ch + 1; |
__func__);
ret = -ENOMEM;
+ kfree(bch);
goto free_chan;
bch->nr = ch;
__func__);
ret = -ENOMEM;
+ kfree(bch);
goto free_chan;
bch->nr = ch + 1;
