drivers/gpio/timbgpio.c: add missing unlock
In an error handling case the lock is not unlocked.  The return is
converted to a goto, to share the unlock at the end of the function.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression E1;
identifier f;
f (...) { <+...
* spin_lock_irqsave (E1,...);
... when != E1
* return ...;
Signed-off-by: Julia Lawall
Cc:
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/gpio/timbgpio.c | 12 ++++++++----
 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/gpio/timbgpio.c b/drivers/gpio/timbgpio.c
index ac4d0f0..ddd0531 100644
--- a/drivers/gpio/timbgpio.c
+++ b/drivers/gpio/timbgpio.c
@@ -131,6 +131,7 @@ static int timbgpio_irq_type(unsigned irq, unsigned trigger)
 	unsigned long flags;
 	u32 lvr, flr, bflr = 0;
 	u32 ver;
+	int ret = 0;
 	if (offset < 0 || offset > tgpio->gpio.ngpio)
 		return -EINVAL;
@@ -154,8 +155,10 @@ static int timbgpio_irq_type(unsigned irq, unsigned trigger)
 	if ((trigger & IRQ_TYPE_EDGE_BOTH) == IRQ_TYPE_EDGE_BOTH) {
-		if (ver < 3)
-			return -EINVAL;
+		if (ver < 3) {
+			ret = -EINVAL;
+			goto out;
 		else {
 			flr |= 1 << offset;
 			bflr |= 1 << offset;
@@ -175,9 +178,10 @@ static int timbgpio_irq_type(unsigned irq, unsigned trigger)
 		iowrite32(bflr, tgpio->membase + TGPIO_BFLR);
 	iowrite32(1 << offset, tgpio->membase + TGPIO_ICR);
-	spin_unlock_irqrestore(&tgpio->lock, flags);
-	return 0;
+out:
+	spin_unlock_irqrestore(&tgpio->lock, flags);
+	return ret;
 static void timbgpio_irq(unsigned int irq, struct irq_desc *desc)
BtrLinux
Privacy Overview
