[S390] arch/s390/kernel: Add missing unlock
In the default case the lock is not unlocked. The return is
converted to a goto, to share the unlock at the end of the function.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression E1;
identifier f;
f (...) { <+...
* spin_lock_irq (E1,...);
... when != E1
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Heiko Carstens
Signed-off-by: Martin Schwidefsky
arch/s390/kernel/topology.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/s390/kernel/topology.c b/arch/s390/kernel/topology.c
index 14ef6f0..247b4c2 100644
--- a/arch/s390/kernel/topology.c
+++ b/arch/s390/kernel/topology.c
@@ -165,10 +165,11 @@ static void tl_to_cores(struct tl_info *info)
default:
clear_cores();
machine_has_topology = 0;
- return;
+ goto out;
tle = next_tle(tle);
+out:
spin_unlock_irq(&topology_lock);
default:
clear_cores();
- return;
+ goto out;
+out:
