drivers/dma/amba-pl08x.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
    when != ret = e3
*if (x == NULL || ...)
  ... when != ret = e4
*  return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Vinod Koul
 drivers/dma/amba-pl08x.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/dma/amba-pl08x.c b/drivers/dma/amba-pl08x.c
index 6fbeebb..d1cc579 100644
--- a/drivers/dma/amba-pl08x.c
+++ b/drivers/dma/amba-pl08x.c
@@ -1892,6 +1892,7 @@ static int pl08x_probe(struct amba_device *adev, const struct amba_id *id)
 	pl08x->pd = dev_get_platdata(&adev->dev);
 	if (!pl08x->pd) {
 		dev_err(&adev->dev, "no platform data supplied\n");
+		ret = -EINVAL;
 		goto out_no_platdata;
@@ -1943,6 +1944,7 @@ static int pl08x_probe(struct amba_device *adev, const struct amba_id *id)
 		dev_err(&adev->dev, "%s failed to allocate "
 			"physical channel holders\n",
 			__func__);
+		ret = -ENOMEM;
 		goto out_no_phychans;
BtrLinux
Privacy Overview
