IB/qib: Fix error return code in qib_init_7322_variables()
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere
in the function.
A simplified version of the semantic match that finds this problem is
as follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
when != ret = e3
*if (x == NULL || ...)
... when != ret = e4
* return ret;
Signed-off-by: Julia Lawall
Acked-by: Mike Marciniszyn
Signed-off-by: Roland Dreier
drivers/infiniband/hw/qib/qib_iba7322.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/infiniband/hw/qib/qib_iba7322.c b/drivers/infiniband/hw/qib/qib_iba7322.c
index 0d7280a..3f6b21e 100644
--- a/drivers/infiniband/hw/qib/qib_iba7322.c
+++ b/drivers/infiniband/hw/qib/qib_iba7322.c
@@ -6346,8 +6346,10 @@ static int qib_init_7322_variables(struct qib_devdata *dd)
dd->piobcnt4k * dd->align4k;
dd->piovl15base = ioremap_nocache(vl15off,
NUM_VL15_BUFS * dd->align4k);
- if (!dd->piovl15base)
+ if (!dd->piovl15base) {
+ ret = -ENOMEM;
goto bail;
qib_7322_set_baseaddrs(dd); /* set chip access pointers now */ |
+ ret = -ENOMEM;
goto bail;
