drivers/cpuidle: Move dereference after NULL test
It does not seem possible that ldev can be NULL, so drop the unnecessary
test.  If ldev can somehow be NULL, then the initialization of last_idx
should be moved below the test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
  ... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Acked-by: Arjan van de Ven
Cc: Ingo Molnar
Cc: Venkatesh Pallipadi
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/cpuidle/governors/ladder.c | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/drivers/cpuidle/governors/ladder.c b/drivers/cpuidle/governors/ladder.c
index a4bec3f..1c1ceb4 100644
--- a/drivers/cpuidle/governors/ladder.c
+++ b/drivers/cpuidle/governors/ladder.c
@@ -69,9 +69,6 @@ static int ladder_select_state(struct cpuidle_device *dev)
 	int last_residency, last_idx = ldev->last_state_idx;
 	int latency_req = pm_qos_requirement(PM_QOS_CPU_DMA_LATENCY);
-	if (unlikely(!ldev))
-		return 0;
 	/* Special case when user has set very strict latency requirement */
 	if (unlikely(latency_req == 0)) {
 		ladder_do_selection(ldev, last_idx, 0);
BtrLinux
Privacy Overview
