arch/s390/kernel/debug.c | 3 ++-
arch/um/drivers/mconsole_kern.c | 16 +++++++---------
arch/x86/kernel/cpu/mtrr/if.c | 11 ++++-------
drivers/leds/led-class.c | 2 +-
drivers/leds/ledtrig-timer.c | 4 ++--
drivers/md/dm-table.c | 6 ++----
drivers/md/md.c | 4 ++--
drivers/parisc/pdc_stable.c | 9 +++------
drivers/platform/x86/thinkpad_acpi.c | 7 ++-----
drivers/pnp/interface.c | 36 ++++++++++-------------------------
drivers/s390/block/dasd_proc.c | 5 +++--
drivers/video/backlight/lcd.c | 4 ++--
drivers/video/display/display-sysfs.c | 2 +-
drivers/video/output.c | 2 +-
fs/cachefiles/daemon.c | 4 ++--
fs/ext4/super.c | 7 ++-----
kernel/params.c | 8 +++-----
lib/argv_split.c | 13 +++----------
lib/dynamic_debug.c | 4 ++--
lib/vsprintf.c | 15 ++++-----------
net/irda/irnet/irnet.h | 1 +
net/irda/irnet/irnet_ppp.c | 8 +++-----
net/netfilter/xt_recent.c | 3 +--
sound/pci/hda/hda_hwdep.c | 7 +++----
24 files changed, 66 insertions(+), 115 deletions(-)
diff --git a/arch/s390/kernel/debug.c b/arch/s390/kernel/debug.c
index 071c81f..0168472 100644
--- a/arch/s390/kernel/debug.c
+++ b/arch/s390/kernel/debug.c
@@ -18,6 +18,7 @@
#include <linux/errno.h>
#include <linux/slab.h>
#include <linux/ctype.h>
+#include <linux/string.h>
#include <linux/sysctl.h>
#include <asm/uaccess.h>
#include <linux/module.h>
@@ -1178,7 +1179,7 @@ debug_get_uint(char *buf)
int rc;
- for(; isspace(*buf); buf++);
+ buf = skip_spaces(buf);
rc = simple_strtoul(buf, &buf, 10);
if(*buf){
rc = -EINVAL;
diff --git a/arch/um/drivers/mconsole_kern.c b/arch/um/drivers/mconsole_kern.c
index f0fa47f..5106924 100644
--- a/arch/um/drivers/mconsole_kern.c
+++ b/arch/um/drivers/mconsole_kern.c
@@ -6,6 +6,7 @@
#include <linux/console.h>
#include <linux/interrupt.h>
#include <linux/list.h>
#include <linux/mm.h>
@@ -131,7 +132,7 @@ void mconsole_proc(struct mc_request *req)
char *ptr = req->request.data, *buf;
ptr += strlen("proc");
- while (isspace(*ptr)) ptr++;
+ ptr = skip_spaces(ptr);
proc = get_fs_type("proc");
if (proc == NULL) {
@@ -212,8 +213,7 @@ void mconsole_proc(struct mc_request *req)
char *ptr = req->request.data;
- ptr++;
snprintf(path, sizeof(path), "/proc/%s", ptr);
fd = sys_open(path, 0, 0);
@@ -560,8 +560,7 @@ void mconsole_config(struct mc_request *req)
int err;
ptr += strlen("config");
- ptr++;
dev = mconsole_find_dev(ptr);
if (dev == NULL) {
mconsole_reply(req, "Bad configuration option", 1, 0);
@@ -588,7 +587,7 @@ void mconsole_remove(struct mc_request *req)
int err, start, end, n;
ptr += strlen("remove");
if (dev == NULL) {
mconsole_reply(req, "Bad remove option", 1, 0);
@@ -712,7 +711,7 @@ void mconsole_sysrq(struct mc_request *req)
ptr += strlen("sysrq");
* With 'b', the system will shut down without a chance to reply,
@@ -757,8 +756,7 @@ void mconsole_stack(struct mc_request *req)
ptr += strlen("stack");
- ptr++;
* Should really check for multiple pids or reject bad args here
diff --git a/arch/x86/kernel/cpu/mtrr/if.c b/arch/x86/kernel/cpu/mtrr/if.c
index 3c1b12d..e006e56 100644
--- a/arch/x86/kernel/cpu/mtrr/if.c
+++ b/arch/x86/kernel/cpu/mtrr/if.c
@@ -4,6 +4,7 @@
#include <linux/proc_fs.h>
#include <linux/init.h>
#define LINE_SIZE 80
@@ -133,8 +134,7 @@ mtrr_write(struct file *file, const char __user *buf, size_t len, loff_t * ppos)
return -EINVAL;
base = simple_strtoull(line + 5, &ptr, 0);
- ptr++;
if (strncmp(ptr, "size=", 5))
return -EINVAL;
@@ -142,14 +142,11 @@ mtrr_write(struct file *file, const char __user *buf, size_t len, loff_t * ppos)
size = simple_strtoull(ptr + 5, &ptr, 0);
if ((base & 0xfff) || (size & 0xfff))
return -EINVAL;
- ptr++;
if (strncmp(ptr, "type=", 5))
return -EINVAL;
- ptr += 5;
- ptr++;
+ ptr = skip_spaces(ptr + 5);
for (i = 0; i < MTRR_NUM_TYPES; ++i) {
if (strcmp(ptr, mtrr_strings[i]))
diff --git a/drivers/leds/led-class.c b/drivers/leds/led-class.c
index f2cc13d..782f958 100644
--- a/drivers/leds/led-class.c
+++ b/drivers/leds/led-class.c
@@ -50,7 +50,7 @@ static ssize_t led_brightness_store(struct device *dev,
unsigned long state = simple_strtoul(buf, &after, 10);
size_t count = after - buf;
- if (*after && isspace(*after))
+ if (isspace(*after))
count++;
if (count == size) {
diff --git a/drivers/leds/ledtrig-timer.c b/drivers/leds/ledtrig-timer.c
index 3b83406..38b3378 100644
--- a/drivers/leds/ledtrig-timer.c
+++ b/drivers/leds/ledtrig-timer.c
@@ -83,7 +83,7 @@ static ssize_t led_delay_on_store(struct device *dev,
count++;
@@ -127,7 +127,7 @@ static ssize_t led_delay_off_store(struct device *dev,
count++;
diff --git a/drivers/md/dm-table.c b/drivers/md/dm-table.c
index 1a6cb3c..91976e8 100644
--- a/drivers/md/dm-table.c
+++ b/drivers/md/dm-table.c
@@ -12,6 +12,7 @@
#include <linux/blkdev.h>
#include <linux/namei.h>
#include <linux/mutex.h>
@@ -600,11 +601,8 @@ int dm_split_args(int *argc, char ***argvp, char *input)
return -ENOMEM;
while (1) {
- start = end;
/* Skip whitespace */
- while (*start && isspace(*start))
- start++;
+ start = skip_spaces(end);
if (!*start)
break; /* success, we hit the end */
diff --git a/drivers/md/md.c b/drivers/md/md.c
index e1f3c17..6f91486 100644
--- a/drivers/md/md.c
+++ b/drivers/md/md.c
@@ -39,6 +39,7 @@
#include <linux/buffer_head.h> /* for invalidate_bdev */
#include <linux/poll.h>
#include <linux/hdreg.h>
#include <linux/random.h>
@@ -3439,8 +3440,7 @@ bitmap_store(mddev_t *mddev, const char *buf, size_t len)
if (*end && !isspace(*end)) break;
bitmap_dirty_bits(mddev->bitmap, chunk, end_chunk);
- buf = end;
- while (isspace(*buf)) buf++;
+ buf = skip_spaces(end);
bitmap_unplug(mddev->bitmap); /* flush the bits to disk */
out:
diff --git a/drivers/parisc/pdc_stable.c b/drivers/parisc/pdc_stable.c
index 13a64bc..0bc5d47 100644
--- a/drivers/parisc/pdc_stable.c
+++ b/drivers/parisc/pdc_stable.c
@@ -779,12 +779,9 @@ static ssize_t pdcs_auto_write(struct kobject *kobj,
read_unlock(&pathentry->rw_lock);
DPRINTK("%s: flags before: 0x%X\n", __func__, flags);
- temp = in;
- while (*temp && isspace(*temp))
- temp++;
+ temp = skip_spaces(in);
c = *temp++ - '0';
if ((c != 0) && (c != 1))
goto parse_error;
diff --git a/drivers/platform/x86/thinkpad_acpi.c b/drivers/platform/x86/thinkpad_acpi.c
index 0ed8480..cf61d6a 100644
--- a/drivers/platform/x86/thinkpad_acpi.c
+++ b/drivers/platform/x86/thinkpad_acpi.c
@@ -1006,11 +1006,8 @@ static int parse_strtoul(const char *buf,
char *endp;
- while (*buf && isspace(*buf))
- buf++;
- *value = simple_strtoul(buf, &endp, 0);
- while (*endp && isspace(*endp))
- endp++;
+ *value = simple_strtoul(skip_spaces(buf), &endp, 0);
+ endp = skip_spaces(endp);
if (*endp || *value > max)
return -EINVAL;
diff --git a/drivers/pnp/interface.c b/drivers/pnp/interface.c
index c3f1c8e..68b0c04 100644
--- a/drivers/pnp/interface.c
+++ b/drivers/pnp/interface.c
@@ -310,8 +310,7 @@ static ssize_t pnp_set_current_resources(struct device *dmdev,
goto done;
- ++buf;
if (!strnicmp(buf, "disable", 7)) {
retval = pnp_disable_dev(dev);
goto done;
@@ -353,19 +352,13 @@ static ssize_t pnp_set_current_resources(struct device *dmdev,
pnp_init_resources(dev);
mutex_lock(&pnp_res_mutex);
while (1) {
- ++buf;
if (!strnicmp(buf, "io", 2)) {
- buf += 2;
- ++buf;
+ buf = skip_spaces(buf + 2);
start = simple_strtoul(buf, &buf, 0);
- ++buf;
if (*buf == '-') {
- buf += 1;
- ++buf;
+ buf = skip_spaces(buf + 1);
end = simple_strtoul(buf, &buf, 0);
} else
end = start;
@@ -373,16 +366,11 @@ static ssize_t pnp_set_current_resources(struct device *dmdev,
continue;
if (!strnicmp(buf, "mem", 3)) {
- buf += 3;
- ++buf;
+ buf = skip_spaces(buf + 3);
- ++buf;
if (*buf == '-') {
- buf += 1;
- ++buf;
} else
end = start;
@@ -390,17 +378,13 @@ static ssize_t pnp_set_current_resources(struct device *dmdev,
continue;
if (!strnicmp(buf, "irq", 3)) {
- buf += 3;
- ++buf;
pnp_add_irq_resource(dev, start, 0);
continue;
if (!strnicmp(buf, "dma", 3)) {
- buf += 3;
- ++buf;
pnp_add_dma_resource(dev, start, 0);
continue;
diff --git a/drivers/s390/block/dasd_proc.c b/drivers/s390/block/dasd_proc.c
index 5f23eca..6315fbd 100644
--- a/drivers/s390/block/dasd_proc.c
+++ b/drivers/s390/block/dasd_proc.c
@@ -14,6 +14,7 @@
#define KMSG_COMPONENT "dasd"
#include <linux/seq_file.h>
#include <linux/vmalloc.h>
@@ -272,10 +273,10 @@ dasd_statistics_write(struct file *file, const char __user *user_buf,
DBF_EVENT(DBF_DEBUG, "/proc/dasd/statictics: '%s'\n", buffer);
/* check for valid verbs */
- for (str = buffer; isspace(*str); str++);
+ str = skip_spaces(buffer);
if (strncmp(str, "set", 3) == 0 && isspace(str[3])) {
/* 'set xxx' was given */
- for (str = str + 4; isspace(*str); str++);
+ str = skip_spaces(str + 4);
if (strcmp(str, "on") == 0) {
/* switch on statistics profiling */
dasd_profile_level = DASD_PROFILE_ON;
diff --git a/drivers/video/backlight/lcd.c b/drivers/video/backlight/lcd.c
index a482dd7..9b3be74 100644
--- a/drivers/video/backlight/lcd.c
+++ b/drivers/video/backlight/lcd.c
@@ -101,7 +101,7 @@ static ssize_t lcd_store_power(struct device *dev,
int power = simple_strtoul(buf, &endp, 0);
size_t size = endp - buf;
- if (*endp && isspace(*endp))
+ if (isspace(*endp))
size++;
if (size != count)
return -EINVAL;
@@ -140,7 +140,7 @@ static ssize_t lcd_store_contrast(struct device *dev,
int contrast = simple_strtoul(buf, &endp, 0);
size++;
if (size != count)
return -EINVAL;
diff --git a/drivers/video/display/display-sysfs.c b/drivers/video/display/display-sysfs.c
index 4830b1b..80abbf3 100644
--- a/drivers/video/display/display-sysfs.c
+++ b/drivers/video/display/display-sysfs.c
@@ -67,7 +67,7 @@ static ssize_t display_store_contrast(struct device *dev,
size = endp - buf;
size++;
if (size != count)
diff --git a/drivers/video/output.c b/drivers/video/output.c
index 5e6439a..5137aa0 100644
--- a/drivers/video/output.c
+++ b/drivers/video/output.c
@@ -50,7 +50,7 @@ static ssize_t video_output_store_state(struct device *dev,
int request_state = simple_strtoul(buf,&endp,0);
size++;
if (size != count)
return -EINVAL;
diff --git a/fs/cachefiles/daemon.c b/fs/cachefiles/daemon.c
index 4618516..c241356 100644
--- a/fs/cachefiles/daemon.c
+++ b/fs/cachefiles/daemon.c
@@ -21,6 +21,7 @@
#include <linux/mount.h>
#include <linux/statfs.h>
#include <linux/fs_struct.h>
#include "internal.h"
@@ -257,8 +258,7 @@ static ssize_t cachefiles_daemon_write(struct file *file,
if (args == data)
goto error;
*args = '\0';
- for (args++; isspace(*args); args++)
- continue;
+ args = skip_spaces(++args);
/* run the appropriate command handler */
diff --git a/fs/ext4/super.c b/fs/ext4/super.c
index 768c111..827bde1 100644
--- a/fs/ext4/super.c
+++ b/fs/ext4/super.c
@@ -2137,11 +2137,8 @@ static int parse_strtoul(const char *buf,
char *endp;
- buf++;
- endp++;
return -EINVAL;
diff --git a/kernel/params.c b/kernel/params.c
index d656c27..cf1b691 100644
--- a/kernel/params.c
+++ b/kernel/params.c
@@ -24,6 +24,7 @@
#include <linux/err.h>
#if 0
#define DEBUGP printk
@@ -122,9 +123,7 @@ static char *next_arg(char *args, char **param, char **val)
next = args + i;
/* Chew up trailing spaces. */
- while (isspace(*next))
- next++;
- return next;
+ return skip_spaces(next);
/* Args looks like "foo=bar,bar2 baz=fuz wiz". */
@@ -139,8 +138,7 @@ int parse_args(const char *name,
DEBUGP("Parsing ARGS: %s\n", args);
/* Chew leading spaces */
- while (isspace(*args))
- args++;
+ args = skip_spaces(args);
while (*args) {
int ret;
diff --git a/lib/argv_split.c b/lib/argv_split.c
index 5205a8d..4b1b083 100644
--- a/lib/argv_split.c
+++ b/lib/argv_split.c
@@ -4,17 +4,10 @@
#include <linux/kernel.h>
-static const char *skip_sep(const char *cp)
- while (*cp && isspace(*cp))
- cp++;
- return cp;
static const char *skip_arg(const char *cp)
while (*cp && !isspace(*cp))
@@ -28,7 +21,7 @@ static int count_argc(const char *str)
int count = 0;
while (*str) {
- str = skip_sep(str);
+ str = skip_spaces(str);
if (*str) {
count++;
str = skip_arg(str);
@@ -82,7 +75,7 @@ char **argv_split(gfp_t gfp, const char *str, int *argcp)
argvp = argv;
while (*str) {
if (*str) {
const char *p = str;
diff --git a/lib/dynamic_debug.c b/lib/dynamic_debug.c
index e22c148..f935029 100644
--- a/lib/dynamic_debug.c
+++ b/lib/dynamic_debug.c
@@ -21,6 +21,7 @@
#include <linux/uaccess.h>
#include <linux/dynamic_debug.h>
#include <linux/debugfs.h>
@@ -209,8 +210,7 @@ static int ddebug_tokenize(char *buf, char *words[], int maxwords)
char *end;
/* Skip leading whitespace */
- buf++;
if (!*buf)
break; /* oh, it was trailing whitespace */
diff --git a/lib/vsprintf.c b/lib/vsprintf.c
index c50733a..7857d4d 100644
--- a/lib/vsprintf.c
+++ b/lib/vsprintf.c
@@ -1766,13 +1766,6 @@ EXPORT_SYMBOL_GPL(bprintf);
#endif /* CONFIG_BINARY_PRINTF */
-static noinline char *skip_space(const char *str)
- while (isspace(*str))
- ++str;
- return (char *)str;
* vsscanf - Unformat a buffer into a list of arguments
* @buf: input buffer
@@ -1794,8 +1787,8 @@ int vsscanf(const char *buf, const char *fmt, va_list args)
* white space, including none, in the input.
if (isspace(*fmt)) {
- fmt = skip_space(fmt);
- str = skip_space(str);
+ fmt = skip_spaces(++fmt);
/* anything that is not a conversion must match exactly */
@@ -1865,7 +1858,7 @@ int vsscanf(const char *buf, const char *fmt, va_list args)
if (field_width == -1)
field_width = INT_MAX;
/* first, skip leading white space in buffer */
/* now copy until next white space */
while (*str && !isspace(*str) && field_width--)
@@ -1907,7 +1900,7 @@ int vsscanf(const char *buf, const char *fmt, va_list args)
/* have some sort of integer conversion.
* first, skip white space in buffer.
digit = *str;
if (is_sign && digit == '-')
diff --git a/net/irda/irnet/irnet.h b/net/irda/irnet/irnet.h
index b001c36..4300df3 100644
--- a/net/irda/irnet/irnet.h
+++ b/net/irda/irnet/irnet.h
@@ -249,6 +249,7 @@
#include <linux/capability.h>
#include <linux/ctype.h> /* isspace() */
+#include <linux/string.h> /* skip_spaces() */
diff --git a/net/irda/irnet/irnet_ppp.c b/net/irda/irnet/irnet_ppp.c
index 7dea882..156020d 100644
--- a/net/irda/irnet/irnet_ppp.c
+++ b/net/irda/irnet/irnet_ppp.c
@@ -76,9 +76,8 @@ irnet_ctrl_write(irnet_socket * ap,
/* Look at the next command */
start = next;
- /* Scrap whitespaces before the command */
- while(isspace(*start))
- start++;
+ /* Scrap whitespaces before the command */
+ start = skip_spaces(start);
/* ',' is our command separator */
next = strchr(start, ',');
@@ -133,8 +132,7 @@ irnet_ctrl_write(irnet_socket * ap,
char * endp;
- while(isspace(*begp))
- begp++;
+ begp = skip_spaces(begp);
/* Convert argument to a number (last arg is the base) */
addr = simple_strtoul(begp, &endp, 16);
diff --git a/net/netfilter/xt_recent.c b/net/netfilter/xt_recent.c
index eb0ceb8..fc70a49 100644
--- a/net/netfilter/xt_recent.c
+++ b/net/netfilter/xt_recent.c
@@ -482,8 +482,7 @@ static ssize_t recent_old_proc_write(struct file *file,
if (copy_from_user(buf, input, size))
return -EFAULT;
- while (isspace(*c))
- c++;
+ c = skip_spaces(c);
if (size - (c - buf) < 5)
return c - buf;
diff --git a/sound/pci/hda/hda_hwdep.c b/sound/pci/hda/hda_hwdep.c
index d243286..40ccb41 100644
--- a/sound/pci/hda/hda_hwdep.c
+++ b/sound/pci/hda/hda_hwdep.c
@@ -24,6 +24,7 @@
#include <linux/compat.h>
#include <linux/firmware.h>
#include <sound/core.h>
#include "hda_codec.h"
@@ -428,8 +429,7 @@ static int parse_hints(struct hda_codec *codec, const char *buf)
char *key, *val;
struct hda_hint *hint;
- buf++;
if (!*buf || *buf == '#' || *buf == '\n')
return 0;
if (*buf == '=')
@@ -444,8 +444,7 @@ static int parse_hints(struct hda_codec *codec, const char *buf)
return -EINVAL;
*val++ = 0;
- while (isspace(*val))
- val++;
+ val = skip_spaces(val);
remove_trail_spaces(key);
remove_trail_spaces(val);
hint = get_hint(codec, key); |
