drivers: staging: rtl8723au: hal: Removed unnecessary parentheses
Author: Tina Johnson <tinajohnson.1234@gmail.com>
Parentheses around the right side of an assignment statement are
unnecessary and hence removed. Coccinelle was used to produce the
patch:
@rule1@
identifier x,y;
constant c;
x =
y << c
x =
y >> c
x =
y + c
x =
y - c
Signed-off-by: Tina Johnson
drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c b/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c
index ba37374..3f9ec9e0 100644
--- a/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c
+++ b/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c
@@ -222,7 +222,7 @@ odm_TXPowerTrackingCallback_ThermalMeter_92C(struct rtw_adapter *Adapter)
if (CCK_index > (CCK_TABLE_SIZE-1))
- CCK_index = (CCK_TABLE_SIZE-1);
+ CCK_index = CCK_TABLE_SIZE-1;
else if (CCK_index < 0)
CCK_index = 0;
CCK_index = 0;
