drivers: staging: iio: meter: Removed unnecessary variable
Author: Tina Johnson <tinajohnson.1234@gmail.com>
Variable ret is used only to store the error code to be returned.
Hence use of ret is removed and the return statement modified.
Coccinelle was used to prepare the patch:
@rule1@
identifier ret;
expression e;
-ret =
+return
        e;
-return ret;
Signed-off-by: Tina Johnson
 drivers/staging/iio/meter/ade7758_ring.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7758_ring.c b/drivers/staging/iio/meter/ade7758_ring.c
index 3792b57..9725a04 100644
--- a/drivers/staging/iio/meter/ade7758_ring.c
+++ b/drivers/staging/iio/meter/ade7758_ring.c
@@ -120,8 +120,7 @@ int ade7758_configure_ring(struct iio_dev *indio_dev)
 	buffer = iio_kfifo_allocate();
 	if (!buffer) {
-		ret = -ENOMEM;
-		return ret;
+		return -ENOMEM;
 	iio_device_attach_buffer(indio_dev, buffer);
BtrLinux
Privacy Overview
