dmascc: Return correct error codes
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
This change has been made with the goal that kernel functions should
return something more descriptive than -1 on failure.
A variable `err` has been introduced for storing error codes.
The return value of kzalloc on failure should return a -1 and not a
-ENOMEM. This was found using Coccinelle. A simplified version of
the semantic patch used is:
expression *e;
identifier l1;
e = kzalloc(...);
if (e == NULL) {
goto l1;
l1:
return -1
+ -ENOMEM
Signed-off-by: David S. Miller
 drivers/net/hamradio/dmascc.c | 13 ++++++++++---
 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/net/hamradio/dmascc.c b/drivers/net/hamradio/dmascc.c
index c3d3777..e4137c1 100644
--- a/drivers/net/hamradio/dmascc.c
+++ b/drivers/net/hamradio/dmascc.c
@@ -451,7 +451,7 @@ static const struct net_device_ops scc_netdev_ops = {
 static int __init setup_adapter(int card_base, int type, int n)
-	int i, irq, chip;
+	int i, irq, chip, err;
 	struct scc_info *info;
 	struct net_device *dev;
 	struct scc_priv *priv;
@@ -463,14 +463,17 @@ static int __init setup_adapter(int card_base, int type, int n)
 	/* Initialize what is necessary for write_scc and write_scc_data */
 	info = kzalloc(sizeof(struct scc_info), GFP_KERNEL | GFP_DMA);
-	if (!info)
+	if (!info) {
+		err = -ENOMEM;
 		goto out;
 	info->dev[0] = alloc_netdev(0, "", NET_NAME_UNKNOWN, dev_setup);
 	if (!info->dev[0]) {
 		printk(KERN_ERR "dmascc: "
 		       "could not allocate memory for %s at %#3x\n",
 		       hw[type].name, card_base);
+		err = -ENOMEM;
 		goto out1;
@@ -479,6 +482,7 @@ static int __init setup_adapter(int card_base, int type, int n)
+		err = -ENOMEM;
 		goto out2;
 	spin_lock_init(&info->register_lock);
@@ -549,6 +553,7 @@ static int __init setup_adapter(int card_base, int type, int n)
 		printk(KERN_ERR
 		       "dmascc: could not find irq of %s at %#3x (irq=%d)\n",
 		       hw[type].name, card_base, irq);
+		err = -ENODEV;
 		goto out3;
@@ -585,11 +590,13 @@ static int __init setup_adapter(int card_base, int type, int n)
 	if (register_netdev(info->dev[0])) {
 		printk(KERN_ERR "dmascc: could not register %s\n",
 		       info->dev[0]->name);
+		err = -ENODEV;
 		goto out3;
 	if (register_netdev(info->dev[1])) {
 		       info->dev[1]->name);
+		err = -ENODEV;
 		goto out4;
@@ -612,7 +619,7 @@ static int __init setup_adapter(int card_base, int type, int n)
       out1:
 	kfree(info);
       out:
-	return -1;
+	return err;
BtrLinux
Privacy Overview
