staging: gdm72xx: compress return logic into one line
Author: Alison Schofield <amsfield22@gmail.com>
Simplify function returns by merging assignment and return into
one command line.
Found with Coccinelle
expression e, ret;
-ret =
+return
e;
-return ret;
Signed-off-by: Alison Schofield
Acked-by: Julia Lawall
drivers/staging/gdm72xx/netlink_k.c | 3 +--
drivers/staging/gdm72xx/usb_boot.c | 4 +---
2 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/gdm72xx/netlink_k.c b/drivers/staging/gdm72xx/netlink_k.c
index b7e5e70..cf0b47c 100644
--- a/drivers/staging/gdm72xx/netlink_k.c
+++ b/drivers/staging/gdm72xx/netlink_k.c
@@ -151,6 +151,5 @@ int netlink_send(struct sock *sock, int group, u16 type, void *msg, int len)
pr_err("netlink_broadcast g=%d, t=%d, l=%d, r=%d\n",
group, type, len, ret);
- ret = 0;
- return ret;
+ return 0;
diff --git a/drivers/staging/gdm72xx/usb_boot.c b/drivers/staging/gdm72xx/usb_boot.c
index 39ca34031..3082987 100644
--- a/drivers/staging/gdm72xx/usb_boot.c
+++ b/drivers/staging/gdm72xx/usb_boot.c
@@ -357,7 +357,5 @@ int usb_emergency(struct usb_device *usbdev)
return ret;
dev_info(&usbdev->dev, "GCT Emergency: Filesystem download success.\n");
- ret = em_fw_reset(usbdev);
- return ret;
+ return em_fw_reset(usbdev);
- ret = 0;
- return ret;
+ return 0;
return ret;
- return ret;
