crypto: tegra-aes – fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Herbert Xu
 drivers/crypto/tegra-aes.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/crypto/tegra-aes.c b/drivers/crypto/tegra-aes.c
index 631149e5..37185e6 100644
--- a/drivers/crypto/tegra-aes.c
+++ b/drivers/crypto/tegra-aes.c
@@ -969,6 +969,7 @@ static int tegra_aes_probe(struct platform_device *pdev)
 	aes_wq = alloc_workqueue("tegra_aes_wq", WQ_HIGHPRI | WQ_UNBOUND, 1);
 	if (!aes_wq) {
 		dev_err(dev, "alloc_workqueue failed\n");
+		err = -ENOMEM;
 		goto out;
BtrLinux
Privacy Overview
