crypto: crypto4xx – fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Herbert Xu
drivers/crypto/amcc/crypto4xx_core.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/crypto/amcc/crypto4xx_core.c b/drivers/crypto/amcc/crypto4xx_core.c
index 802e851..f88e3d8 100644
--- a/drivers/crypto/amcc/crypto4xx_core.c
+++ b/drivers/crypto/amcc/crypto4xx_core.c
@@ -1226,6 +1226,7 @@ static int __init crypto4xx_probe(struct platform_device *ofdev)
core_dev->dev->ce_base = of_iomap(ofdev->dev.of_node, 0);
if (!core_dev->dev->ce_base) {
dev_err(dev, "failed to of_iomap\n");
+ rc = -ENOMEM;
goto err_iomap;
+ rc = -ENOMEM;
goto err_iomap;
