crypto: qat – cleanup coccicheck warning – NULL check before freeing functions
Author: Bruce Allan <bruce.w.allan@intel.com>
Analyzing with coccinelle MODE=report...
Please check for false positives in the output before submitting a patch.
When using "patch" mode, carefully review the patch before submitting it.
drivers/crypto/qat/qat_dh895xcc/adf_isr.c:191:3-8: WARNING: NULL check
before freeing functions like kfree, debugfs_remove,
debugfs_remove_recursive or usb_free_urb is not needed. Maybe consider
reorganizing relevant code to avoid passing NULL values.
drivers/crypto/qat/qat_dh895xcc/adf_isr.c:208:3-8: WARNING: NULL check
Signed-off-by: Bruce Allan
Signed-off-by: Herbert Xu
 drivers/crypto/qat/qat_dh895xcc/adf_isr.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/crypto/qat/qat_dh895xcc/adf_isr.c b/drivers/crypto/qat/qat_dh895xcc/adf_isr.c
index 67ec61e..c9212b9 100644
--- a/drivers/crypto/qat/qat_dh895xcc/adf_isr.c
+++ b/drivers/crypto/qat/qat_dh895xcc/adf_isr.c
@@ -186,10 +186,8 @@ static int adf_isr_alloc_msix_entry_table(struct adf_accel_dev *accel_dev)
 	accel_dev->accel_pci_dev.msix_entries.names = names;
 	return 0;
 err:
-	for (i = 0; i < msix_num_entries; i++) {
-		if (*(names + i))
-			kfree(*(names + i));
+	for (i = 0; i < msix_num_entries; i++)
+		kfree(*(names + i));
 	kfree(entries);
 	kfree(names);
 	return -ENOMEM;
@@ -203,10 +201,8 @@ static void adf_isr_free_msix_entry_table(struct adf_accel_dev *accel_dev)
 	int i;
 	kfree(accel_dev->accel_pci_dev.msix_entries.entries);
-		if (*(names + i))
 	kfree(names);
BtrLinux
Privacy Overview
