fs/befs/btree.c | 53 +++++++++++++++++++++++++++++------------------------
1 file changed, 29 insertions(+), 24 deletions(-)
diff --git a/fs/befs/btree.c b/fs/befs/btree.c
index 9c7faa8..0826e91 100644
--- a/fs/befs/btree.c
+++ b/fs/befs/btree.c
@@ -78,11 +78,11 @@
* In memory structure of each btree node
-typedef struct {
+struct befs_btree_node {
befs_host_btree_nodehead head; /* head of node converted to cpu byteorder */
struct buffer_head *bh;
befs_btree_nodehead *od_node; /* on disk node */
-} befs_btree_node;
/* local constants */
static const befs_off_t befs_bt_inval = 0xffffffffffffffffULL;
@@ -90,27 +90,30 @@ static const befs_off_t befs_bt_inval = 0xffffffffffffffffULL;
/* local functions */
static int befs_btree_seekleaf(struct super_block *sb, befs_data_stream * ds,
befs_btree_super * bt_super,
- befs_btree_node * this_node,
+ struct befs_btree_node *this_node,
befs_off_t * node_off);
static int befs_bt_read_super(struct super_block *sb, befs_data_stream * ds,
befs_btree_super * sup);
static int befs_bt_read_node(struct super_block *sb, befs_data_stream * ds,
- befs_btree_node * node, befs_off_t node_off);
+ struct befs_btree_node *node,
+ befs_off_t node_off);
-static int befs_leafnode(befs_btree_node * node);
+static int befs_leafnode(struct befs_btree_node *node);
-static fs16 *befs_bt_keylen_index(befs_btree_node * node);
+static fs16 *befs_bt_keylen_index(struct befs_btree_node *node);
-static fs64 *befs_bt_valarray(befs_btree_node * node);
+static fs64 *befs_bt_valarray(struct befs_btree_node *node);
-static char *befs_bt_keydata(befs_btree_node * node);
+static char *befs_bt_keydata(struct befs_btree_node *node);
-static int befs_find_key(struct super_block *sb, befs_btree_node * node,
+static int befs_find_key(struct super_block *sb,
const char *findkey, befs_off_t * value);
-static char *befs_bt_get_key(struct super_block *sb, befs_btree_node * node,
+static char *befs_bt_get_key(struct super_block *sb,
int index, u16 * keylen);
static int befs_compare_strings(const void *key1, int keylen1,
@@ -191,7 +194,7 @@ befs_bt_read_super(struct super_block *sb, befs_data_stream * ds,
static int
+ struct befs_btree_node *node, befs_off_t node_off)
uint off = 0;
@@ -247,7 +250,7 @@ int
befs_btree_find(struct super_block *sb, befs_data_stream * ds,
const char *key, befs_off_t * value)
- befs_btree_node *this_node = NULL;
+ struct befs_btree_node *this_node = NULL;
befs_btree_super bt_super;
befs_off_t node_off;
int res;
@@ -260,11 +263,11 @@ befs_btree_find(struct super_block *sb, befs_data_stream * ds,
goto error;
- this_node = kmalloc(sizeof (befs_btree_node),
+ this_node = kmalloc(sizeof(struct befs_btree_node),
GFP_NOFS);
if (!this_node) {
befs_error(sb, "befs_btree_find() failed to allocate %zu "
- "bytes of memory", sizeof (befs_btree_node));
+ "bytes of memory", sizeof(struct befs_btree_node));
goto error;
@@ -333,7 +336,7 @@ befs_btree_find(struct super_block *sb, befs_data_stream * ds,
* Use binary search instead of a linear.
static int
-befs_find_key(struct super_block *sb, befs_btree_node * node,
+befs_find_key(struct super_block *sb, struct befs_btree_node *node,
int first, last, mid;
@@ -417,7 +420,7 @@ befs_btree_read(struct super_block *sb, befs_data_stream * ds,
loff_t key_no, size_t bufsize, char *keybuf, size_t * keysize,
befs_off_t * value)
- befs_btree_node *this_node;
+ struct befs_btree_node *this_node;
befs_off_t node_off = 0;
int cur_key;
@@ -436,9 +439,10 @@ befs_btree_read(struct super_block *sb, befs_data_stream * ds,
goto error;
- if ((this_node = kmalloc(sizeof (befs_btree_node), GFP_NOFS)) == NULL) {
+ this_node = kmalloc(sizeof(struct befs_btree_node), GFP_NOFS);
+ if (this_node == NULL) {
befs_error(sb, "befs_btree_read() failed to allocate %zu "
goto error;
@@ -545,7 +549,8 @@ befs_btree_read(struct super_block *sb, befs_data_stream * ds,
static int
- befs_btree_super * bt_super, befs_btree_node * this_node,
+ befs_btree_super *bt_super,
@@ -600,7 +605,7 @@ befs_btree_seekleaf(struct super_block *sb, befs_data_stream * ds,
* Return 1 if leaf, 0 if interior
static int
-befs_leafnode(befs_btree_node * node)
+befs_leafnode(struct befs_btree_node *node)
/* all interior nodes (and only interior nodes) have an overflow node */
if (node->head.overflow == befs_bt_inval)
@@ -623,7 +628,7 @@ befs_leafnode(befs_btree_node * node)
* Except that rounding up to 8 works, and rounding up to 4 doesn't.
static fs16 *
-befs_bt_keylen_index(befs_btree_node * node)
+befs_bt_keylen_index(struct befs_btree_node *node)
const int keylen_align = 8;
unsigned long int off =
@@ -644,7 +649,7 @@ befs_bt_keylen_index(befs_btree_node * node)
* of the node pointed to by the node header
static fs64 *
-befs_bt_valarray(befs_btree_node * node)
+befs_bt_valarray(struct befs_btree_node *node)
void *keylen_index_start = (void *) befs_bt_keylen_index(node);
size_t keylen_index_size = node->head.all_key_count * sizeof (fs16);
@@ -660,7 +665,7 @@ befs_bt_valarray(befs_btree_node * node)
static char *
-befs_bt_keydata(befs_btree_node * node)
+befs_bt_keydata(struct befs_btree_node *node)
return (char *) ((void *) node->od_node + sizeof (befs_btree_nodehead));
@@ -676,7 +681,7 @@ befs_bt_keydata(befs_btree_node * node)
* Returns NULL on failure (bad input) and sets *@keylen = 0
static char *
-befs_bt_get_key(struct super_block *sb, befs_btree_node * node,
+befs_bt_get_key(struct super_block *sb, struct befs_btree_node *node,
int prev_key_end; |
