crypto: caam – Remove unneeded ‘ret’ variable
Author: Fabio Estevam <fabio.estevam@freescale.com>
Variable 'ret' is only used for returning the value 0.
We can make it simpler and just return 0 instead.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/returnvar.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Herbert Xu
 drivers/crypto/caam/ctrl.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/crypto/caam/ctrl.c b/drivers/crypto/caam/ctrl.c
index 37c2d8d..4f174ee 100644
--- a/drivers/crypto/caam/ctrl.c
+++ b/drivers/crypto/caam/ctrl.c
@@ -298,7 +298,7 @@ static int caam_remove(struct platform_device *pdev)
 	struct device *ctrldev;
 	struct caam_drv_private *ctrlpriv;
 	struct caam_ctrl __iomem *ctrl;
-	int ring, ret = 0;
+	int ring;
 	ctrldev = &pdev->dev;
 	ctrlpriv = dev_get_drvdata(ctrldev);
@@ -328,7 +328,7 @@ static int caam_remove(struct platform_device *pdev)
 	clk_disable_unprepare(ctrlpriv->caam_aclk);
 	clk_disable_unprepare(ctrlpriv->caam_emi_slow);
-	return ret;
+	return 0;
BtrLinux
Privacy Overview
