drivers/clk/berlin/berlin2-pll.c | 4 ++--
drivers/clk/clk-xgene.c | 22 +++++++++++-----------
drivers/clk/pistachio/clk-pll.c | 4 ++--
drivers/clk/qcom/clk-branch.c | 2 +-
drivers/clk/rockchip/clk-inverter.c | 2 +-
drivers/clk/rockchip/clk-mmc-phase.c | 2 +-
drivers/clk/samsung/clk-pll.c | 18 +++++++++---------
drivers/clk/shmobile/clk-div6.c | 2 +-
drivers/clk/st/clk-flexgen.c | 4 ++--
drivers/clk/st/clkgen-fsyn.c | 18 +++++++++---------
drivers/clk/st/clkgen-mux.c | 2 +-
drivers/clk/st/clkgen-pll.c | 8 ++++----
drivers/clk/tegra/clk-pll.c | 8 ++++----
drivers/clk/ti/apll.c | 4 ++--
drivers/clk/ti/clkt_dflt.c | 8 ++++----
drivers/clk/ti/clockdomain.c | 14 +++++++-------
drivers/clk/ux500/clk-prcmu.c | 16 ++++++++--------
drivers/clk/ux500/clk-sysctrl.c | 2 +-
18 files changed, 70 insertions(+), 70 deletions(-)
diff --git a/drivers/clk/berlin/berlin2-pll.c b/drivers/clk/berlin/berlin2-pll.c
index f4b8d32..1c2294d 100644
--- a/drivers/clk/berlin/berlin2-pll.c
+++ b/drivers/clk/berlin/berlin2-pll.c
@@ -61,7 +61,7 @@ berlin2_pll_recalc_rate(struct clk_hw *hw, unsigned long parent_rate)
fbdiv = (val >> map->fbdiv_shift) & FBDIV_MASK;
rfdiv = (val >> map->rfdiv_shift) & RFDIV_MASK;
if (rfdiv == 0) {
- pr_warn("%s has zero rfdiv\n", __clk_get_name(hw->clk));
+ pr_warn("%s has zero rfdiv\n", clk_hw_get_name(hw));
rfdiv = 1;
@@ -70,7 +70,7 @@ berlin2_pll_recalc_rate(struct clk_hw *hw, unsigned long parent_rate)
vcodiv = map->vcodiv[vcodivsel];
if (vcodiv == 0) {
pr_warn("%s has zero vcodiv (index %d)\n",
- __clk_get_name(hw->clk), vcodivsel);
+ clk_hw_get_name(hw), vcodivsel);
vcodiv = 1;
diff --git a/drivers/clk/clk-xgene.c b/drivers/clk/clk-xgene.c
index 4caee93..96a6190 100644
--- a/drivers/clk/clk-xgene.c
+++ b/drivers/clk/clk-xgene.c
@@ -74,7 +74,7 @@ static int xgene_clk_pll_is_enabled(struct clk_hw *hw)
u32 data;
data = xgene_clk_read(pllclk->reg + pllclk->pll_offset);
- pr_debug("%s pll %s\n", __clk_get_name(hw->clk),
+ pr_debug("%s pll %s\n", clk_hw_get_name(hw),
data & REGSPEC_RESET_F1_MASK ? "disabled" : "enabled");
return data & REGSPEC_RESET_F1_MASK ? 0 : 1;
@@ -112,7 +112,7 @@ static unsigned long xgene_clk_pll_recalc_rate(struct clk_hw *hw,
fref = parent_rate / nref;
fvco = fref * nfb;
- pr_debug("%s pll recalc rate %ld parent %ld\n", __clk_get_name(hw->clk),
+ pr_debug("%s pll recalc rate %ld parent %ld\n", clk_hw_get_name(hw),
fvco / nout, parent_rate);
return fvco / nout;
@@ -225,7 +225,7 @@ static int xgene_clk_enable(struct clk_hw *hw)
spin_lock_irqsave(pclk->lock, flags);
if (pclk->param.csr_reg != NULL) {
- pr_debug("%s clock enabled\n", __clk_get_name(hw->clk));
+ pr_debug("%s clock enabled\n", clk_hw_get_name(hw));
reg = __pa(pclk->param.csr_reg);
/* First enable the clock */
data = xgene_clk_read(pclk->param.csr_reg +
@@ -234,7 +234,7 @@ static int xgene_clk_enable(struct clk_hw *hw)
xgene_clk_write(data, pclk->param.csr_reg +
pclk->param.reg_clk_offset);
pr_debug("%s clock PADDR base %pa clk offset 0x%08X mask 0x%08X value 0x%08X\n",
- __clk_get_name(hw->clk), ®,
+ clk_hw_get_name(hw), ®,
pclk->param.reg_clk_offset, pclk->param.reg_clk_mask,
data);
@@ -245,7 +245,7 @@ static int xgene_clk_enable(struct clk_hw *hw)
pclk->param.reg_csr_offset);
pr_debug("%s CSR RESET PADDR base %pa csr offset 0x%08X mask 0x%08X value 0x%08X\n",
pclk->param.reg_csr_offset, pclk->param.reg_csr_mask,
data);
@@ -266,7 +266,7 @@ static void xgene_clk_disable(struct clk_hw *hw)
- pr_debug("%s clock disabled\n", __clk_get_name(hw->clk));
+ pr_debug("%s clock disabled\n", clk_hw_get_name(hw));
/* First put the CSR in reset */
@@ -292,10 +292,10 @@ static int xgene_clk_is_enabled(struct clk_hw *hw)
u32 data = 0;
- pr_debug("%s clock checking\n", __clk_get_name(hw->clk));
+ pr_debug("%s clock checking\n", clk_hw_get_name(hw));
- pr_debug("%s clock is %s\n", __clk_get_name(hw->clk),
+ pr_debug("%s clock is %s\n", clk_hw_get_name(hw),
data & pclk->param.reg_clk_mask ? "enabled" :
"disabled");
@@ -318,13 +318,13 @@ static unsigned long xgene_clk_recalc_rate(struct clk_hw *hw,
data &= (1 << pclk->param.reg_divider_width) - 1;
pr_debug("%s clock recalc rate %ld parent %ld\n",
parent_rate / data, parent_rate);
return parent_rate / data;
} else {
- __clk_get_name(hw->clk), parent_rate, parent_rate);
+ clk_hw_get_name(hw), parent_rate, parent_rate);
return parent_rate;
@@ -356,7 +356,7 @@ static int xgene_clk_set_rate(struct clk_hw *hw, unsigned long rate,
data |= divider;
xgene_clk_write(data, pclk->param.divider_reg +
pclk->param.reg_divider_offset);
- pr_debug("%s clock set rate %ld\n", __clk_get_name(hw->clk),
+ pr_debug("%s clock set rate %ld\n", clk_hw_get_name(hw),
parent_rate / divider_save);
} else {
divider_save = 1;
diff --git a/drivers/clk/pistachio/clk-pll.c b/drivers/clk/pistachio/clk-pll.c
index e17dada..addfec7 100644
--- a/drivers/clk/pistachio/clk-pll.c
+++ b/drivers/clk/pistachio/clk-pll.c
@@ -174,7 +174,7 @@ static int pll_gf40lp_frac_set_rate(struct clk_hw *hw, unsigned long rate,
struct pistachio_pll_rate_table *params;
int enabled = pll_gf40lp_frac_is_enabled(hw);
u32 val, vco, old_postdiv1, old_postdiv2;
- const char *name = __clk_get_name(hw->clk);
+ const char *name = clk_hw_get_name(hw);
if (rate < MIN_OUTPUT_FRAC || rate > MAX_OUTPUT_FRAC)
return -EINVAL;
@@ -316,7 +316,7 @@ static int pll_gf40lp_laint_set_rate(struct clk_hw *hw, unsigned long rate,
int enabled = pll_gf40lp_laint_is_enabled(hw);
if (rate < MIN_OUTPUT_LA || rate > MAX_OUTPUT_LA)
return -EINVAL;
diff --git a/drivers/clk/qcom/clk-branch.c b/drivers/clk/qcom/clk-branch.c
index 6b4d2bc..26f7af31 100644
--- a/drivers/clk/qcom/clk-branch.c
+++ b/drivers/clk/qcom/clk-branch.c
@@ -75,7 +75,7 @@ static int clk_branch_wait(const struct clk_branch *br, bool enabling,
bool (check_halt)(const struct clk_branch *, bool))
bool voted = br->halt_check & BRANCH_VOTED;
- const char *name = __clk_get_name(br->clkr.hw.clk);
+ const char *name = clk_hw_get_name(&br->clkr.hw);
/* Skip checking halt bit if the clock is in hardware gated mode */
if (clk_branch_in_hwcg_mode(br))
diff --git a/drivers/clk/rockchip/clk-inverter.c b/drivers/clk/rockchip/clk-inverter.c
index 8054fdb..7cbf43b 100644
--- a/drivers/clk/rockchip/clk-inverter.c
+++ b/drivers/clk/rockchip/clk-inverter.c
@@ -50,7 +50,7 @@ static int rockchip_inv_set_phase(struct clk_hw *hw, int degrees)
val = !!degrees;
} else {
pr_err("%s: unsupported phase %d for %s\n",
- __func__, degrees, __clk_get_name(hw->clk));
+ __func__, degrees, clk_hw_get_name(hw));
return -EINVAL;
diff --git a/drivers/clk/rockchip/clk-mmc-phase.c b/drivers/clk/rockchip/clk-mmc-phase.c
index 77e1909..9b61342 100644
--- a/drivers/clk/rockchip/clk-mmc-phase.c
+++ b/drivers/clk/rockchip/clk-mmc-phase.c
@@ -108,7 +108,7 @@ static int rockchip_mmc_set_phase(struct clk_hw *hw, int degrees)
writel(HIWORD_UPDATE(raw_value, 0x07ff, mmc_clock->shift), mmc_clock->reg);
pr_debug("%s->set_phase(%d) delay_nums=%u reg[0x%p]=0x%03x actual_degrees=%d\n",
- __clk_get_name(hw->clk), degrees, delay_num,
+ clk_hw_get_name(hw), degrees, delay_num,
mmc_clock->reg, raw_value>>(mmc_clock->shift),
rockchip_mmc_get_phase(hw)
diff --git a/drivers/clk/samsung/clk-pll.c b/drivers/clk/samsung/clk-pll.c
index e939426..b7dd396 100644
--- a/drivers/clk/samsung/clk-pll.c
+++ b/drivers/clk/samsung/clk-pll.c
@@ -182,7 +182,7 @@ static int samsung_pll35xx_set_rate(struct clk_hw *hw, unsigned long drate,
rate = samsung_get_pll_settings(pll, drate);
if (!rate) {
pr_err("%s: Invalid rate : %lu for pll clk %s\n", __func__,
- drate, __clk_get_name(hw->clk));
+ drate, clk_hw_get_name(hw));
return -EINVAL;
@@ -290,7 +290,7 @@ static int samsung_pll36xx_set_rate(struct clk_hw *hw, unsigned long drate,
if (!rate) {
return -EINVAL;
@@ -405,7 +405,7 @@ static int samsung_pll45xx_set_rate(struct clk_hw *hw, unsigned long drate,
if (!rate) {
return -EINVAL;
@@ -457,7 +457,7 @@ static int samsung_pll45xx_set_rate(struct clk_hw *hw, unsigned long drate,
if (ktime_to_ms(delta) > PLL_TIMEOUT_MS) {
pr_err("%s: could not lock PLL %s\n",
- __func__, __clk_get_name(hw->clk));
+ __func__, clk_hw_get_name(hw));
return -EFAULT;
@@ -556,7 +556,7 @@ static int samsung_pll46xx_set_rate(struct clk_hw *hw, unsigned long drate,
if (!rate) {
return -EINVAL;
@@ -616,7 +616,7 @@ static int samsung_pll46xx_set_rate(struct clk_hw *hw, unsigned long drate,
return -EFAULT;
@@ -774,7 +774,7 @@ static int samsung_s3c2410_pll_set_rate(struct clk_hw *hw, unsigned long drate,
if (!rate) {
return -EINVAL;
@@ -1015,7 +1015,7 @@ static int samsung_pll2550xx_set_rate(struct clk_hw *hw, unsigned long drate,
if (!rate) {
return -EINVAL;
@@ -1113,7 +1113,7 @@ static int samsung_pll2650xx_set_rate(struct clk_hw *hw, unsigned long drate,
if (!rate) {
return -EINVAL;
diff --git a/drivers/clk/shmobile/clk-div6.c b/drivers/clk/shmobile/clk-div6.c
index ee66f49..b4c8d67 100644
--- a/drivers/clk/shmobile/clk-div6.c
+++ b/drivers/clk/shmobile/clk-div6.c
@@ -139,7 +139,7 @@ static u8 cpg_div6_clock_get_parent(struct clk_hw *hw)
pr_err("%s: %s DIV6 clock set to invalid parent %u\n",
- __func__, __clk_get_name(hw->clk), hw_index);
+ __func__, clk_hw_get_name(hw), hw_index);
return 0;
diff --git a/drivers/clk/st/clk-flexgen.c b/drivers/clk/st/clk-flexgen.c
index 965b13b..bd355ee 100644
--- a/drivers/clk/st/clk-flexgen.c
+++ b/drivers/clk/st/clk-flexgen.c
@@ -45,7 +45,7 @@ static int flexgen_enable(struct clk_hw *hw)
clk_gate_ops.enable(fgate_hw);
- pr_debug("%s: flexgen output enabled\n", __clk_get_name(hw->clk));
+ pr_debug("%s: flexgen output enabled\n", clk_hw_get_name(hw));
return 0;
@@ -59,7 +59,7 @@ static void flexgen_disable(struct clk_hw *hw)
clk_gate_ops.disable(fgate_hw);
- pr_debug("%s: flexgen output disabled\n", __clk_get_name(hw->clk));
+ pr_debug("%s: flexgen output disabled\n", clk_hw_get_name(hw));
static int flexgen_is_enabled(struct clk_hw *hw)
diff --git a/drivers/clk/st/clkgen-fsyn.c b/drivers/clk/st/clkgen-fsyn.c
index aa3117d..83ccf14 100644
--- a/drivers/clk/st/clkgen-fsyn.c
+++ b/drivers/clk/st/clkgen-fsyn.c
@@ -513,7 +513,7 @@ static unsigned long quadfs_pll_fs660c32_recalc_rate(struct clk_hw *hw,
params.ndiv = CLKGEN_READ(pll, ndiv);
if (clk_fs660c32_vco_get_rate(parent_rate, ¶ms, &rate))
pr_err("%s:%s error calculating rate\n",
- __clk_get_name(hw->clk), __func__);
+ clk_hw_get_name(hw), __func__);
pll->ndiv = params.ndiv;
@@ -558,7 +558,7 @@ static long quadfs_pll_fs660c32_round_rate(struct clk_hw *hw, unsigned long rate
clk_fs660c32_vco_get_rate(*prate, ¶ms, &rate);
pr_debug("%s: %s new rate %ld [sdiv=0x%x,md=0x%x,pe=0x%x,nsdiv3=%u]\n",
rate, (unsigned int)params.sdiv,
(unsigned int)params.mdiv,
(unsigned int)params.pe, (unsigned int)params.nsdiv);
@@ -581,7 +581,7 @@ static int quadfs_pll_fs660c32_set_rate(struct clk_hw *hw, unsigned long rate,
clk_fs660c32_vco_get_rate(parent_rate, ¶ms, &hwrate);
pr_debug("%s: %s new rate %ld [ndiv=0x%x]\n",
hwrate, (unsigned int)params.ndiv);
if (!hwrate)
@@ -745,7 +745,7 @@ static int quadfs_fsynth_enable(struct clk_hw *hw)
struct st_clk_quadfs_fsynth *fs = to_quadfs_fsynth(hw);
unsigned long flags = 0;
- pr_debug("%s: %s\n", __func__, __clk_get_name(hw->clk));
+ pr_debug("%s: %s\n", __func__, clk_hw_get_name(hw));
quadfs_fsynth_program_rate(fs);
@@ -770,7 +770,7 @@ static void quadfs_fsynth_disable(struct clk_hw *hw)
if (fs->lock)
spin_lock_irqsave(fs->lock, flags);
@@ -787,7 +787,7 @@ static int quadfs_fsynth_is_enabled(struct clk_hw *hw)
u32 nsb = CLKGEN_READ(fs, nsb[fs->chan]);
pr_debug("%s: %s enable bit = 0x%x\n",
- __func__, __clk_get_name(hw->clk), nsb);
+ __func__, clk_hw_get_name(hw), nsb);
return fs->data->standby_polarity ? !nsb : !!nsb;
@@ -946,10 +946,10 @@ static unsigned long quadfs_recalc_rate(struct clk_hw *hw,
if (clk_fs_get_rate(parent_rate, ¶ms, &rate)) {
- pr_debug("%s:%s rate %lu\n", __clk_get_name(hw->clk), __func__, rate);
+ pr_debug("%s:%s rate %lu\n", clk_hw_get_name(hw), __func__, rate);
return rate;
@@ -962,7 +962,7 @@ static long quadfs_round_rate(struct clk_hw *hw, unsigned long rate,
rate = quadfs_find_best_rate(hw, rate, *prate, ¶ms);
rate, (unsigned int)params.sdiv, (unsigned int)params.mdiv,
diff --git a/drivers/clk/st/clkgen-mux.c b/drivers/clk/st/clkgen-mux.c
index 81f2372..4f7f6c0 100644
--- a/drivers/clk/st/clkgen-mux.c
+++ b/drivers/clk/st/clkgen-mux.c
@@ -139,7 +139,7 @@ static u8 clkgena_divmux_get_parent(struct clk_hw *hw)
genamux->muxsel = clk_mux_ops.get_parent(mux_hw);
if ((s8)genamux->muxsel < 0) {
pr_debug("%s: %s: Invalid parent, setting to default.\n",
genamux->muxsel = 0;
diff --git a/drivers/clk/st/clkgen-pll.c b/drivers/clk/st/clkgen-pll.c
index cc2b52e..47a38a9 100644
--- a/drivers/clk/st/clkgen-pll.c
+++ b/drivers/clk/st/clkgen-pll.c
@@ -292,7 +292,7 @@ static unsigned long recalc_stm_pll800c65(struct clk_hw *hw,
res = (uint64_t)2 * (uint64_t)parent_rate * (uint64_t)ndiv;
rate = (unsigned long)div64_u64(res, mdiv * (1 << pdiv));
return rate;
@@ -317,7 +317,7 @@ static unsigned long recalc_stm_pll1600c65(struct clk_hw *hw,
/* Note: input is divided by 1000 to avoid overflow */
rate = ((2 * (parent_rate / 1000) * ndiv) / mdiv) * 1000;
return rate;
@@ -339,7 +339,7 @@ static unsigned long recalc_stm_pll3200c32(struct clk_hw *hw,
/* Note: input is divided to avoid overflow */
rate = ((2 * (parent_rate/1000) * ndiv) / idf) * 1000;
return rate;
@@ -366,7 +366,7 @@ static unsigned long recalc_stm_pll1200c32(struct clk_hw *hw,
rate = (((parent_rate / 1000) * ldf) / (odf * idf)) * 1000;
return rate;
diff --git a/drivers/clk/tegra/clk-pll.c b/drivers/clk/tegra/clk-pll.c
index 69fea7d..d6d4ecb 100644
--- a/drivers/clk/tegra/clk-pll.c
+++ b/drivers/clk/tegra/clk-pll.c
@@ -264,7 +264,7 @@ static int clk_pll_wait_for_lock(struct tegra_clk_pll *pll)
pr_err("%s: Timed out waiting for pll %s lock\n", __func__,
- __clk_get_name(pll->hw.clk));
+ clk_hw_get_name(&pll->hw));
return -1;
@@ -595,7 +595,7 @@ static int clk_pll_set_rate(struct clk_hw *hw, unsigned long rate,
if (pll->params->flags & TEGRA_PLL_FIXED) {
if (rate != pll->params->fixed_rate) {
pr_err("%s: Can not change %s fixed rate %lu to %lu\n",
pll->params->fixed_rate, rate);
return -EINVAL;
@@ -605,7 +605,7 @@ static int clk_pll_set_rate(struct clk_hw *hw, unsigned long rate,
if (_get_table_rate(hw, &cfg, rate, parent_rate) &&
_calc_rate(hw, &cfg, rate, parent_rate)) {
pr_err("%s: Failed to set %s rate %lu\n", __func__,
- __clk_get_name(hw->clk), rate);
+ clk_hw_get_name(hw), rate);
WARN_ON(1);
return -EINVAL;
@@ -663,7 +663,7 @@ static unsigned long clk_pll_recalc_rate(struct clk_hw *hw,
if (_get_table_rate(hw, &sel, pll->params->fixed_rate,
parent_rate)) {
pr_err("Clock %s has unknown fixed frequency\n",
- __clk_get_name(hw->clk));
+ clk_hw_get_name(hw));
BUG();
return pll->params->fixed_rate;
diff --git a/drivers/clk/ti/apll.c b/drivers/clk/ti/apll.c
index 24febd4..f3eab6e 100644
--- a/drivers/clk/ti/apll.c
+++ b/drivers/clk/ti/apll.c
@@ -50,7 +50,7 @@ static int dra7_apll_enable(struct clk_hw *hw)
if (!ad)
return -EINVAL;
- clk_name = __clk_get_name(clk->hw.clk);
+ clk_name = clk_hw_get_name(&clk->hw);
state <<= __ffs(ad->idlest_mask);
@@ -273,7 +273,7 @@ static int omap2_apll_enable(struct clk_hw *hw)
if (i == MAX_APLL_WAIT_TRIES) {
pr_warn("%s failed to transition to locked\n",
- __clk_get_name(clk->hw.clk));
+ clk_hw_get_name(&clk->hw));
return -EBUSY;
diff --git a/drivers/clk/ti/clkt_dflt.c b/drivers/clk/ti/clkt_dflt.c
index a176b8a..90d7d8a 100644
--- a/drivers/clk/ti/clkt_dflt.c
+++ b/drivers/clk/ti/clkt_dflt.c
@@ -110,7 +110,7 @@ static void _omap2_module_wait_ready(struct clk_hw_omap *clk)
if (r) {
/* IDLEST register not in the CM module */
_wait_idlest_generic(clk, idlest_reg, (1 << idlest_bit),
- idlest_val, __clk_get_name(clk->hw.clk));
+ idlest_val, clk_hw_get_name(&clk->hw));
} else {
ti_clk_ll_ops->cm_wait_module_ready(0, prcm_mod, idlest_reg_id,
idlest_bit);
@@ -216,7 +216,7 @@ int omap2_dflt_clk_enable(struct clk_hw *hw)
if (ret) {
WARN(1,
"%s: could not enable %s's clockdomain %s: %d\n",
clk->clkdm_name, ret);
return ret;
@@ -224,7 +224,7 @@ int omap2_dflt_clk_enable(struct clk_hw *hw)
if (unlikely(!clk->enable_reg)) {
pr_err("%s: %s missing enable_reg\n", __func__,
ret = -EINVAL;
goto err;
@@ -270,7 +270,7 @@ void omap2_dflt_clk_disable(struct clk_hw *hw)
* controlled by its parent.
pr_err("%s: independent clock %s has no enable_reg\n",
return;
diff --git a/drivers/clk/ti/clockdomain.c b/drivers/clk/ti/clockdomain.c
index 362a62c..b9bc3b8 100644
--- a/drivers/clk/ti/clockdomain.c
+++ b/drivers/clk/ti/clockdomain.c
@@ -48,23 +48,23 @@ int omap2_clkops_enable_clkdm(struct clk_hw *hw)
if (unlikely(!clk->clkdm)) {
pr_err("%s: %s: no clkdm set ?!\n", __func__,
return -EINVAL;
if (unlikely(clk->enable_reg))
pr_err("%s: %s: should use dflt_clk_enable ?!\n", __func__,
if (ti_clk_get_features()->flags & TI_CLK_DISABLE_CLKDM_CONTROL) {
pr_err("%s: %s: clkfw-based clockdomain control disabled ?!\n",
return 0;
ret = ti_clk_ll_ops->clkdm_clk_enable(clk->clkdm, hw->clk);
WARN(ret, "%s: could not enable %s's clockdomain %s: %d\n",
- __func__, __clk_get_name(hw->clk), clk->clkdm_name, ret);
+ __func__, clk_hw_get_name(hw), clk->clkdm_name, ret);
return ret;
@@ -86,17 +86,17 @@ void omap2_clkops_disable_clkdm(struct clk_hw *hw)
return;
pr_err("%s: %s: should use dflt_clk_disable ?!\n", __func__,
return;
diff --git a/drivers/clk/ux500/clk-prcmu.c b/drivers/clk/ux500/clk-prcmu.c
index bf63c96..7f34382 100644
--- a/drivers/clk/ux500/clk-prcmu.c
+++ b/drivers/clk/ux500/clk-prcmu.c
@@ -43,7 +43,7 @@ static void clk_prcmu_unprepare(struct clk_hw *hw)
struct clk_prcmu *clk = to_clk_prcmu(hw);
if (prcmu_request_clock(clk->cg_sel, false))
pr_err("clk_prcmu: %s failed to disable %s.\n", __func__,
else
clk->is_prepared = 0;
@@ -101,11 +101,11 @@ static int clk_prcmu_opp_prepare(struct clk_hw *hw)
if (!clk->opp_requested) {
err = prcmu_qos_add_requirement(PRCMU_QOS_APE_OPP,
- (char *)__clk_get_name(hw->clk),
+ (char *)clk_hw_get_name(hw),
100);
if (err) {
pr_err("clk_prcmu: %s fail req APE OPP for %s.\n",
return err;
clk->opp_requested = 1;
@@ -114,7 +114,7 @@ static int clk_prcmu_opp_prepare(struct clk_hw *hw)
err = prcmu_request_clock(clk->cg_sel, true);
if (err) {
prcmu_qos_remove_requirement(PRCMU_QOS_APE_OPP,
- (char *)__clk_get_name(hw->clk));
+ (char *)clk_hw_get_name(hw));
clk->opp_requested = 0;
return err;
@@ -129,13 +129,13 @@ static void clk_prcmu_opp_unprepare(struct clk_hw *hw)
if (prcmu_request_clock(clk->cg_sel, false)) {
return;
if (clk->opp_requested) {
@@ -151,7 +151,7 @@ static int clk_prcmu_opp_volt_prepare(struct clk_hw *hw)
err = prcmu_request_ape_opp_100_voltage(true);
if (err) {
pr_err("clk_prcmu: %s fail req APE OPP VOLT for %s.\n",
return err;
@@ -174,7 +174,7 @@ static void clk_prcmu_opp_volt_unprepare(struct clk_hw *hw)
return;
diff --git a/drivers/clk/ux500/clk-sysctrl.c b/drivers/clk/ux500/clk-sysctrl.c
index e364c9d..266ddea 100644
--- a/drivers/clk/ux500/clk-sysctrl.c
+++ b/drivers/clk/ux500/clk-sysctrl.c
@@ -52,7 +52,7 @@ static void clk_sysctrl_unprepare(struct clk_hw *hw)
struct clk_sysctrl *clk = to_clk_sysctrl(hw);
if (ab8500_sysctrl_clear(clk->reg_sel[0], clk->reg_mask[0]))
dev_err(clk->dev, "clk_sysctrl: %s fail to clear %s.\n",
static unsigned long clk_sysctrl_recalc_rate(struct clk_hw *hw, |
