cosa: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/wan/cosa.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/net/wan/cosa.c b/drivers/net/wan/cosa.c
index 88d121d..bcfa01a 100644
--- a/drivers/net/wan/cosa.c
+++ b/drivers/net/wan/cosa.c
@@ -579,6 +579,7 @@ static int cosa_probe(int base, int irq, int dma)
 		/* Register the network interface */
 		if (!(chan->netdev = alloc_hdlcdev(chan))) {
 			pr_warn("%s: alloc_hdlcdev failed\n", chan->name);
+			err = -ENOMEM;
 			goto err_hdlcdev;
 		dev_to_hdlc(chan->netdev)->attach = cosa_net_attach;
BtrLinux
Privacy Overview
