HID: logitech-hidpp: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Reviewed-by: Benjamin Tissoires
Signed-off-by: Jiri Kosina
drivers/hid/hid-logitech-hidpp.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/hid/hid-logitech-hidpp.c b/drivers/hid/hid-logitech-hidpp.c
index 8e9cb25..b3cf6fd 100644
--- a/drivers/hid/hid-logitech-hidpp.c
+++ b/drivers/hid/hid-logitech-hidpp.c
@@ -1220,6 +1220,7 @@ static int hidpp_probe(struct hid_device *hdev, const struct hid_device_id *id)
connected = hidpp_is_connected(hidpp);
if (id->group != HID_GROUP_LOGITECH_DJ_DEVICE) {
if (!connected) {
+ ret = -ENODEV;
hid_err(hdev, "Device not connected");
hid_device_io_stop(hdev);
goto hid_parse_fail; |
if (!connected) {
+ ret = -ENODEV;
