clk: sunxi: fix handling return value of of_property_match_string
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative values, so its result should
be assigned to signed variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Signed-off-by: Maxime Ripard
 drivers/clk/sunxi/clk-sun8i-bus-gates.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/sunxi/clk-sun8i-bus-gates.c b/drivers/clk/sunxi/clk-sun8i-bus-gates.c
index b8c7753..e32d18b 100644
--- a/drivers/clk/sunxi/clk-sun8i-bus-gates.c
+++ b/drivers/clk/sunxi/clk-sun8i-bus-gates.c
@@ -47,12 +47,12 @@ static void __init sun8i_h3_bus_gates_init(struct device_node *node)
 		return;
 	for (i = 0; i < ARRAY_SIZE(names); i++) {
-		index = of_property_match_string(node, "clock-names",
-						 names[i]);
-		if (index < 0)
+		int idx = of_property_match_string(node, "clock-names",
+						   names[i]);
+		if (idx < 0)
 			return;
-		parents[i] = of_clk_get_parent_name(node, index);
+		parents[i] = of_clk_get_parent_name(node, idx);
 	clk_data = kmalloc(sizeof(struct clk_onecell_data), GFP_KERNEL);
BtrLinux
Privacy Overview
