ath9k_htc: fix handling return value of ath9k_hw_calibrate
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative values in case of error.
Its result should be then tested for such case.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Signed-off-by: Kalle Valo
 drivers/net/wireless/ath/ath9k/htc_drv_main.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wireless/ath/ath9k/htc_drv_main.c b/drivers/net/wireless/ath/ath9k/htc_drv_main.c
index a680a97..fe1fd1a 100644
--- a/drivers/net/wireless/ath/ath9k/htc_drv_main.c
+++ b/drivers/net/wireless/ath/ath9k/htc_drv_main.c
@@ -834,7 +834,7 @@ void ath9k_htc_ani_work(struct work_struct *work)
 		if (longcal || shortcal)
 			common->ani.caldone =
 				ath9k_hw_calibrate(ah, ah->curchan,
-						   ah->rxchainmask, longcal);
+						ah->rxchainmask, longcal) > 0;
 		ath9k_htc_ps_restore(priv);
