clk: scpi: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each iteration,
so a break out of the loop requires an of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_available_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Acked-by: Sudeep Holla
Signed-off-by: Stephen Boyd
 drivers/clk/clk-scpi.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/clk/clk-scpi.c b/drivers/clk/clk-scpi.c
index 0b501a9..cd0f272 100644
--- a/drivers/clk/clk-scpi.c
+++ b/drivers/clk/clk-scpi.c
@@ -292,6 +292,7 @@ static int scpi_clocks_probe(struct platform_device *pdev)
 		ret = scpi_clk_add(dev, child, match);
 		if (ret) {
 			scpi_clocks_remove(pdev);
 			return ret;
BtrLinux
Privacy Overview
