clk: imx31: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_compatible_node performs an of_node_get on each iteration, so a
break out of the loop requires an of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
local idexpression n;
expression e;
for_each_compatible_node(n,...) {
of_node_put(n);
e = n
+ of_node_put(n);
? break;
... when != n
Signed-off-by: Julia Lawall
Signed-off-by: Stephen Boyd
drivers/clk/imx/clk-imx31.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx31.c b/drivers/clk/imx/clk-imx31.c
index f65b8b1..6a96414 100644
--- a/drivers/clk/imx/clk-imx31.c
+++ b/drivers/clk/imx/clk-imx31.c
@@ -233,8 +233,10 @@ int __init mx31_clocks_init_dt(void)
if (!of_device_is_compatible(np, "fsl,imx-osc26m"))
continue;
- if (!of_property_read_u32(np, "clock-frequency", &fref))
+ if (!of_property_read_u32(np, "clock-frequency", &fref)) {
+ of_node_put(np);
break;
_mx31_clocks_init(fref); |
continue;
+ of_node_put(np);
break;
