clk: imx27: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_compatible_node performs an of_node_get on each iteration, so a
break out of the loop requires an of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
local idexpression n;
expression e;
 for_each_compatible_node(n,...) {
   of_node_put(n);
   e = n
+  of_node_put(n);
?  break;
... when != n
Signed-off-by: Julia Lawall
Signed-off-by: Stephen Boyd
 drivers/clk/imx/clk-imx27.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx27.c b/drivers/clk/imx/clk-imx27.c
index 0d7b8df..cf5cf75 100644
--- a/drivers/clk/imx/clk-imx27.c
+++ b/drivers/clk/imx/clk-imx27.c
@@ -261,8 +261,10 @@ static void __init mx27_clocks_init_dt(struct device_node *np)
 		if (!of_device_is_compatible(refnp, "fsl,imx-osc26m"))
 			continue;
-		if (!of_property_read_u32(refnp, "clock-frequency", &fref))
+		if (!of_property_read_u32(refnp, "clock-frequency", &fref)) {
+			of_node_put(refnp);
 			break;
 	ccm = of_iomap(np, 0);
BtrLinux
Privacy Overview
