ceph, rbd: delete unnecessary checks before two function calls
Author: SF Markus Elfring <elfring@users.sourceforge.net>
The functions ceph_put_snap_context() and iput() test whether their
argument is NULL and then return immediately. Thus the test around the
call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
[idryomov@redhat.com: squashed rbd.c hunk, changelog]
Signed-off-by: Ilya Dryomov
 drivers/block/rbd.c  | 3 +--
 fs/ceph/caps.c       | 3 +--
 fs/ceph/mds_client.c | 6 ++----
 fs/ceph/snap.c       | 9 +++------
 4 files changed, 7 insertions(+), 14 deletions(-)
diff --git a/drivers/block/rbd.c b/drivers/block/rbd.c
index 27b71a0..3c34ab5 100644
--- a/drivers/block/rbd.c
+++ b/drivers/block/rbd.c
@@ -3405,8 +3405,7 @@ err_rq:
 	if (result)
 		rbd_warn(rbd_dev, "%s %llx at %llx result %d",
 			 obj_op_name(op_type), length, offset, result);
-	if (snapc)
-		ceph_put_snap_context(snapc);
+	ceph_put_snap_context(snapc);
 	blk_end_request_all(rq, result);
diff --git a/fs/ceph/caps.c b/fs/ceph/caps.c
index cefca66..eb1bf1f 100644
--- a/fs/ceph/caps.c
+++ b/fs/ceph/caps.c
@@ -3137,8 +3137,7 @@ flush_cap_releases:
 done:
 	mutex_unlock(&session->s_mutex);
 done_unlocked:
-	if (inode)
-		iput(inode);
+	iput(inode);
 	return;
 bad:
diff --git a/fs/ceph/mds_client.c b/fs/ceph/mds_client.c
index 5a47ed7..fc74617 100644
--- a/fs/ceph/mds_client.c
+++ b/fs/ceph/mds_client.c
@@ -524,8 +524,7 @@ void ceph_mdsc_release_request(struct kref *kref)
 	if (req->r_locked_dir)
 		ceph_put_cap_refs(ceph_inode(req->r_locked_dir), CEPH_CAP_PIN);
-	if (req->r_target_inode)
-		iput(req->r_target_inode);
+	iput(req->r_target_inode);
 	if (req->r_dentry)
 		dput(req->r_dentry);
 	if (req->r_old_dentry)
@@ -1066,8 +1065,7 @@ out:
 	session->s_cap_iterator = NULL;
 	spin_unlock(&session->s_cap_lock);
-	if (last_inode)
-		iput(last_inode);
+	iput(last_inode);
 	if (old_cap)
 		ceph_put_cap(session->s_mdsc, old_cap);
diff --git a/fs/ceph/snap.c b/fs/ceph/snap.c
index f01645a..c1cc993 100644
--- a/fs/ceph/snap.c
+++ b/fs/ceph/snap.c
@@ -365,8 +365,7 @@ static int build_snap_context(struct ceph_snap_realm *realm)
 	     realm->ino, realm, snapc, snapc->seq,
 	     (unsigned int) snapc->num_snaps);
-	if (realm->cached_context)
-		ceph_put_snap_context(realm->cached_context);
+	ceph_put_snap_context(realm->cached_context);
 	realm->cached_context = snapc;
 	return 0;
@@ -590,15 +589,13 @@ static void queue_realm_cap_snaps(struct ceph_snap_realm *realm)
 		if (!inode)
 			continue;
 		spin_unlock(&realm->inodes_with_caps_lock);
-		if (lastinode)
-			iput(lastinode);
+		iput(lastinode);
 		lastinode = inode;
 		ceph_queue_cap_snap(ci);
 		spin_lock(&realm->inodes_with_caps_lock);
-	if (lastinode)
-		iput(lastinode);
+	iput(lastinode);
 	list_for_each_entry(child, &realm->children, child_item) {
 		dout("queue_realm_cap_snaps %p %llx queue child %p %llx\n",
BtrLinux
Privacy Overview
