Staging: rtl8188eu: Use put_unaligned_le32
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le32.
This is done using Coccinelle and semantic patch used is as follows:
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le32(y);
  <+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le32(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Vaishali Thakkar
 drivers/staging/rtl8188eu/hal/rtl8188e_cmd.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8188eu/hal/rtl8188e_cmd.c b/drivers/staging/rtl8188eu/hal/rtl8188e_cmd.c
index 023a3d8..ce55d9d 100644
--- a/drivers/staging/rtl8188eu/hal/rtl8188e_cmd.c
+++ b/drivers/staging/rtl8188eu/hal/rtl8188e_cmd.c
@@ -150,11 +150,9 @@ u8 rtl8188e_set_raid_cmd(struct adapter *adapt, u32 mask)
 	struct hal_data_8188e *haldata = GET_HAL_DATA(adapt);
 	if (haldata->fw_ractrl) {
-		__le32 lmask;
 		memset(buf, 0, 3);
-		lmask = cpu_to_le32(mask);
-		memcpy(buf, &lmask, 3);
+		put_unaligned_le32(mask, buf);
 		FillH2CCmd_88E(adapt, H2C_DM_MACID_CFG, 3, buf);
 	} else {
