brcm80211: fix usage of freq_reg_info()
Author: Luis R. Rodriguez <mcgrof@do-not-panic.com>
freq_reg_info() expects KHz and not MHz, fix this. In
this case we'll now be getting the no-ir flags cleared
on channels for any channel when the country IE trusts
that channel.
struct ieee80211_channel *ch;
struct wiphy *wiphy;
const struct ieee80211_reg_rule *rule;
-rule = freq_reg_info(wiphy, ch->center_freq);
+rule = freq_reg_info(wiphy, MHZ_TO_KHZ(ch->center_freq));
Generated-by: Coccinelle SmPL
Cc: Julia Lawall
Cc: Peter Senna Tschudin
Cc: Seth Forshee
Cc: Arend van Spriel
Reported-by: Mihir Shete
Signed-off-by: Luis R. Rodriguez
Acked-by: Arend van Spriel
Signed-off-by: John W. Linville
 drivers/net/wireless/brcm80211/brcmsmac/channel.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/wireless/brcm80211/brcmsmac/channel.c b/drivers/net/wireless/brcm80211/brcmsmac/channel.c
index ef05df0..635ae03 100644
--- a/drivers/net/wireless/brcm80211/brcmsmac/channel.c
+++ b/drivers/net/wireless/brcm80211/brcmsmac/channel.c
@@ -679,7 +679,8 @@ brcms_reg_apply_beaconing_flags(struct wiphy *wiphy,
 				continue;
 			if (initiator == NL80211_REGDOM_SET_BY_COUNTRY_IE) {
-				rule = freq_reg_info(wiphy, ch->center_freq);
+				rule = freq_reg_info(wiphy,
+						     MHZ_TO_KHZ(ch->center_freq));
 				if (IS_ERR(rule))
 					continue;
BtrLinux
Privacy Overview
