rtlwifi: fix usage of freq_reg_info()
Author: Luis R. Rodriguez <mcgrof@do-not-panic.com>
freq_reg_info() expects KHz and not MHz, fix this. In
this case we'll now be getting the no-ir flags cleared
on channels for any channel when the country IE trusts
that channel.
struct ieee80211_channel *ch;
struct wiphy *wiphy;
const struct ieee80211_reg_rule *rule;
-rule = freq_reg_info(wiphy, ch->center_freq);
+rule = freq_reg_info(wiphy, MHZ_TO_KHZ(ch->center_freq));
Generated-by: Coccinelle SmPL
Cc: Julia Lawall
Cc: Peter Senna Tschudin
Cc: Larry Finger
Reported-by: Mihir Shete
Signed-off-by: Luis R. Rodriguez
Acked-by: Larry Finger
Signed-off-by: John W. Linville
drivers/net/wireless/rtlwifi/regd.c | 7 ++++---
1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wireless/rtlwifi/regd.c b/drivers/net/wireless/rtlwifi/regd.c
index 89e3656..a4eb9b2 100644
--- a/drivers/net/wireless/rtlwifi/regd.c
+++ b/drivers/net/wireless/rtlwifi/regd.c
@@ -168,7 +168,8 @@ static void _rtl_reg_apply_beaconing_flags(struct wiphy *wiphy,
(ch->flags & IEEE80211_CHAN_RADAR))
continue;
if (initiator == NL80211_REGDOM_SET_BY_COUNTRY_IE) {
- reg_rule = freq_reg_info(wiphy, ch->center_freq);
+ reg_rule = freq_reg_info(wiphy,
+ MHZ_TO_KHZ(ch->center_freq));
if (IS_ERR(reg_rule))
continue;
@@ -226,7 +227,7 @@ static void _rtl_reg_apply_active_scan_flags(struct wiphy *wiphy,
ch = &sband->channels[11]; /* CH 12 */
+ reg_rule = freq_reg_info(wiphy, MHZ_TO_KHZ(ch->center_freq));
if (!IS_ERR(reg_rule)) {
if (!(reg_rule->flags & NL80211_RRF_NO_IR))
if (ch->flags & IEEE80211_CHAN_NO_IR)
@@ -234,7 +235,7 @@ static void _rtl_reg_apply_active_scan_flags(struct wiphy *wiphy,
ch = &sband->channels[12]; /* CH 13 */
if (ch->flags & IEEE80211_CHAN_NO_IR) |
continue;
continue;
