bnx2x: Remove sparse and coccinelle warnings
Author: Yuval Mintz <yuvalmin@broadcom.com>
This patch solves several sparse issues as well as an unneeded semicolon
found via coccinelle.
Signed-off-by: Yuval Mintz
Signed-off-by: Dmitry Kravkov
Signed-off-by: Ariel Elior
Signed-off-by: Eilon Greenstein
Signed-off-by: David S. Miller
 drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.c     | 9 ++++++---
 drivers/net/ethernet/broadcom/bnx2x/bnx2x_ethtool.c | 8 +++++---
 drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c    | 2 +-
 3 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.c b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.c
index d342c5a..ec3aa1d 100644
--- a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.c
+++ b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.c
@@ -1722,7 +1722,7 @@ static int bnx2x_req_irq(struct bnx2x *bp)
 	return request_irq(irq, bnx2x_interrupt, flags, bp->dev->name, bp->dev);
-int bnx2x_setup_irqs(struct bnx2x *bp)
+static int bnx2x_setup_irqs(struct bnx2x *bp)
 	int rc = 0;
 	if (bp->flags & USING_MSIX_FLAG &&
@@ -3543,9 +3543,12 @@ static void bnx2x_update_pbds_gso_enc(struct sk_buff *skb,
 	/* outer IP header info */
 	if (xmit_type & XMIT_CSUM_V4) {
 		struct iphdr *iph = ip_hdr(skb);
+		u16 csum = (__force u16)(~iph->check) -
+			   (__force u16)iph->tot_len -
+			   (__force u16)iph->frag_off;
 		pbd2->fw_ip_csum_wo_len_flags_frag =
-			bswab16(csum_fold((~iph->check) -
-					  iph->tot_len - iph->frag_off));
+			bswab16(csum_fold((__force __wsum)csum));
 	} else {
 		pbd2->fw_ip_hdr_to_payload_w =
 			hlen_w - ((sizeof(struct ipv6hdr)) >> 1);
diff --git a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_ethtool.c b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_ethtool.c
index 7c6faeb..b8c067d 100644
--- a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_ethtool.c
+++ b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_ethtool.c
@@ -1391,7 +1391,7 @@ static bool bnx2x_is_nvm_accessible(struct bnx2x *bp)
 					  bp->pm_cap + PCI_PM_CTRL, &pm);
 	if ((rc && !netif_running(dev)) ||
-	    (!rc && ((pm & PCI_PM_CTRL_STATE_MASK) != PCI_D0)))
+	    (!rc && ((pm & PCI_PM_CTRL_STATE_MASK) != (__force u16)PCI_D0)))
 		return false;
 	return true;
@@ -1610,8 +1610,10 @@ static int bnx2x_nvram_write1(struct bnx2x *bp, u32 offset, u8 *data_buf,
 		val = be32_to_cpu(val_be);
-		val &= ~le32_to_cpu(0xff << BYTE_OFFSET(offset));
-		val |= le32_to_cpu(*data_buf << BYTE_OFFSET(offset));
+		val &= ~le32_to_cpu((__force __le32)
+				    (0xff << BYTE_OFFSET(offset)));
+		val |= le32_to_cpu((__force __le32)
+				   (*data_buf << BYTE_OFFSET(offset)));
 		rc = bnx2x_nvram_write_dword(bp, align_offset, val,
 					     cmd_flags);
diff --git a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
index 7318988..740518b 100644
--- a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
+++ b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
@@ -615,7 +615,7 @@ void bnx2x_read_dmae(struct bnx2x *bp, u32 src_addr, u32 len32)
 	if (rc) {
 		BNX2X_ERR("DMAE returned failure %d\n", rc);
 		bnx2x_panic();
 static void bnx2x_write_dmae_phys_len(struct bnx2x *bp, dma_addr_t phys_addr,
BtrLinux
Privacy Overview
