drivers/parport/share.c: use kzalloc
Author: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
Replaced calls to kmalloc and memset with kzalloc.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/parport/share.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/parport/share.c b/drivers/parport/share.c
index a848e02..6a83ee1 100644
--- a/drivers/parport/share.c
+++ b/drivers/parport/share.c
@@ -282,14 +282,13 @@ struct parport *parport_register_port(unsigned long base, int irq, int dma,
int device;
char *name;
- tmp = kmalloc(sizeof(struct parport), GFP_KERNEL);
+ tmp = kzalloc(sizeof(struct parport), GFP_KERNEL);
if (!tmp) {
printk(KERN_WARNING "parport: memory squeeze\n");
return NULL;
/* Init our structure */
- memset(tmp, 0, sizeof(struct parport));
tmp->base = base;
tmp->irq = irq;
tmp->dma = dma; |
int device;
char *name;
if (!tmp) {
return NULL;
tmp->base = base;
tmp->irq = irq;
tmp->dma = dma;
