Bluetooth: Use PTR_RET function
Author: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
Used PTR_RET function instead of IS_ERR and PTR_ERR.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu
Signed-off-by: Gustavo Padovan
net/bluetooth/hci_sysfs.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/net/bluetooth/hci_sysfs.c b/net/bluetooth/hci_sysfs.c
index 23b4e24..ff38561 100644
--- a/net/bluetooth/hci_sysfs.c
+++ b/net/bluetooth/hci_sysfs.c
@@ -590,10 +590,8 @@ int __init bt_sysfs_init(void)
bt_debugfs = debugfs_create_dir("bluetooth", NULL);
bt_class = class_create(THIS_MODULE, "bluetooth");
- if (IS_ERR(bt_class))
- return PTR_ERR(bt_class);
- return 0;
+ return PTR_RET(bt_class);
void bt_sysfs_cleanup(void) |
- return 0;
