drivers: char: Use PTR_RET function
Author: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
Used PTR_RET function instead of IS_ERR and PTR_ERR.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu
 drivers/char/tile-srom.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/char/tile-srom.c b/drivers/char/tile-srom.c
index 3b22a60..2e2036e 100644
--- a/drivers/char/tile-srom.c
+++ b/drivers/char/tile-srom.c
@@ -371,7 +371,7 @@ static int srom_setup_minor(struct srom_dev *srom, int index)
 	dev = device_create(srom_class, &platform_bus,
 			    MKDEV(srom_major, index), srom, "%d", index);
-	return IS_ERR(dev) ? PTR_ERR(dev) : 0;
+	return PTR_RET(dev);
 /** srom_init() - Initialize the driver's module. */
